On one of my two OwnCloud 9.x systems, OwnCloud Crashes with a PHP Exception when a User is Authenticated.
LDAP users should be authenticated.
{“reqId”:“WxZMVvPN8MMZFK2OLh3zqAAAAAg”,“remoteAddr”:“192.168.0.4”,“app”:“index”,“message”:“Exception: {“Exception”:“InvalidArgumentException”,“Message”:”",“Code”:0,“Trace”:"#0 \/usr\/share\/owncloud\/lib\/private\/Share20\/DefaultShareProvider.php(791): OC\\Share20\\Share->setSharedBy(NULL)\n#1 \/usr\/share\/owncloud\/lib\/private\/Share20\/DefaultShareProvider.php(648): OC\\Share20\\DefaultShareProvider->createShare(Array)\n#2 \/usr\/share\/owncloud\/lib\/private\/Share20\/Manager.php(960): OC\\Share20\\DefaultShareProvider->getSharedWith(‘4054b596-267c-1…’, 0, NULL, -1, 0)\n#3 \/usr\/share\/owncloud\/apps\/files_sharing\/lib\/MountProvider.php(69): OC\\Share20\\Manager->getSharedWith(‘4054b596-267c-1…’, 0, NULL, -1)\n#4 \/usr\/share\/owncloud\/lib\/private\/Files\/Config\/MountProviderCollection.php(76): OCA\\Files_Sharing\\MountProvider->getMountsForUser(Object(OC\\User\\User), Object(OC\\Files\\Storage\\StorageFactory))\n#5 [internal function]: OC\\Files\\Config\\MountProviderCollection->OC\\Files\\Config\\{closure}(Object(OCA\\Files_Sharing\\MountProvider))\n#6 \/usr\/share\/owncloud\/lib\/private\/Files\/Config\/MountProviderCollection.php(77): array_map(Object(Closure), Array)\n#7 \/usr\/share\/owncloud\/lib\/private\/Files\/Filesystem.php(443): OC\\Files\\Config\\MountProviderCollection->getMountsForUser(Object(OC\\User\\User))\n#8 \/usr\/share\/owncloud\/lib\/private\/Files\/Filesystem.php(373): OC\\Files\\Filesystem::initMountPoints(‘4054b596-267c-1…’)\n#9 \/usr\/share\/owncloud\/lib\/private\/legacy\/util.php(231): OC\\Files\\Filesystem::init(‘4054b596-267c-1…’, ‘\/4054b596-267c-…’)\n#10 \/usr\/share\/owncloud\/lib\/base.php(890): OC_Util::setupFS()\n#11 \/usr\/share\/owncloud\/index.php(54): OC::handleRequest()\n#12 {main}",“File”:"\/usr\/share\/owncloud\/lib\/private\/Share20\/Share.php",“Line”:287}",“level”:3,“time”:“2018-06-05T08:39:51+00:00”,“method”:“GET”,“url”:"/owncloud/index.php/apps/files/",“user”:“4054b596-267c-102c-918a-d9d787c9dc10”}
{“reqId”:“WxZMXD7ht@w2nimqTfgyugAAAAE”,“remoteAddr”:“192.168.0.4”,“app”:“index”,“message”:“Exception: {“Exception”:“InvalidArgumentException”,“Message”:”",“Code”:0,“Trace”:"#0 \/usr\/share\/owncloud\/lib\/private\/Share20\/DefaultShareProvider.php(791): OC\\Share20\\Share->setSharedBy(NULL)\n#1 \/usr\/share\/owncloud\/lib\/private\/Share20\/DefaultShareProvider.php(648): OC\\Share20\\DefaultShareProvider->createShare(Array)\n#2 \/usr\/share\/owncloud\/lib\/private\/Share20\/Manager.php(960): OC\\Share20\\DefaultShareProvider->getSharedWith(‘4054b596-267c-1…’, 0, NULL, -1, 0)\n#3 \/usr\/share\/owncloud\/apps\/files_sharing\/lib\/MountProvider.php(69): OC\\Share20\\Manager->getSharedWith(‘4054b596-267c-1…’, 0, NULL, -1)\n#4 \/usr\/share\/owncloud\/lib\/private\/Files\/Config\/MountProviderCollection.php(76): OCA\\Files_Sharing\\MountProvider->getMountsForUser(Object(OC\\User\\User), Object(OC\\Files\\Storage\\StorageFactory))\n#5 [internal function]: OC\\Files\\Config\\MountProviderCollection->OC\\Files\\Config\\{closure}(Object(OCA\\Files_Sharing\\MountProvider))\n#6 \/usr\/share\/owncloud\/lib\/private\/Files\/Config\/MountProviderCollection.php(77): array_map(Object(Closure), Array)\n#7 \/usr\/share\/owncloud\/lib\/private\/Files\/Filesystem.php(443): OC\\Files\\Config\\MountProviderCollection->getMountsForUser(Object(OC\\User\\User))\n#8 \/usr\/share\/owncloud\/lib\/private\/Files\/Filesystem.php(373): OC\\Files\\Filesystem::initMountPoints(‘4054b596-267c-1…’)\n#9 \/usr\/share\/owncloud\/lib\/private\/legacy\/util.php(231): OC\\Files\\Filesystem::init(‘4054b596-267c-1…’, ‘\/4054b596-267c-…’)\n#10 \/usr\/share\/owncloud\/lib\/base.php(890): OC_Util::setupFS()\n#11 \/usr\/share\/owncloud\/index.php(54): OC::handleRequest()\n#12 {main}",“File”:"\/usr\/share\/owncloud\/lib\/private\/Share20\/Share.php",“Line”:287}",“level”:3,“time”:“2018-06-05T08:39:57+00:00”,“method”:“GET”,“url”:"/owncloud/index.php/apps/gallery/config?extramediatypes=1",“user”:“4054b596-267c-102c-918a-d9d787c9dc10”}
{“reqId”:“WxZMXFW3W-zbbMtUTsjfZQAAAAc”,“remoteAddr”:“192.168.0.4”,“app”:“PHP”,“message”:“InvalidArgumentException: at /usr/share/owncloud/lib/private/Share20/Share.php#287”,“level”:3,“time”:“2018-06-05T08:39:57+00:00”,“method”:“GET”,“url”:"/owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json",“user”:“4054b596-267c-102c-918a-d9d787c9dc10”}
Mageia Linux 6
Apache
MariaDB
9.1.8
Updated from 9.0.11
OS RPM Package. However, only this one node failed the upgrade.
