Please help us by providing the following info. Before posting please make sure that you’re running the latest available version for your oC release: Changelog - ownCloud + https://owncloud.org/changelog/desktop/
1.Copy 116 Go from usb key to user directory
2.run following commands :
sudo -u www-data php occ files:scan --all
sudo -u www-data php occ files:cleanup
3. Syncing folder with desktop app
Should be quick as all datas has been already copied from USB key to hard drive
The syncronisation is up to 5 days…
Client version: OCC
Client operating system: 2.2.4 build 6408
Operating system: Raspbian GNU/Linux 8.0 (jessie)
Web server: apache2
Database: MySQL 5.5.50-0+deb8u1
PHP version: PHP 5.6.24-0+deb8u1 (cli) (built: Jul 27 2016 00:06:04) with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2016, by Zend Technologies
ownCloud version : 9.1.0
