We just fresh installed owncloud 9.1. We can login, upload, download files as normal.
We found there is a owncloud.log and it is full of "curl_multi_exec() has been disabled for security reasons" message. It is because our web hosting does not allow curl.
May I know is there any impact if we use owncloud without curl?
I think its not really possible to say if the disabled curl_multi_exec() has any impact so instead please contact the support of your hoster and ask him to allow this function.
Without Curl your Installation will not be capable to perform any Kind of communication to the outside world like install apps from the appstore, check for Server updates, using the updater will not be possible, most exteralnal storage Integration like Amazon s3 will not work.
To be honest: choose a different Hoster - it will not be fun
