Hello guys,
I finished installing ownCloud on my raspberry pi 3b. I used this link for instructions: Raspberry Pi ownCloud: Your Personal Cloud Storage - Pi My Life Up .
My OS is “Raspbian GNU/Linux 8 (jessie)”, and i mounted a 3TB external hard drive to the PI.
Everything seemed to work fine. Upload/download works when i use my computer to access the cloud.
But when i try to upload something from the mobile app (I use the android version),
my raspberry pi crashes and becomes unresponsive. I cannot access it via SSH (using Putty). The only way to gain access is to pull the power and plug it back in.
This is very strange to me, because when i try to upload the same file from my computer, it works.
Can anyone help ?
