Hello
I would like to use ownCloud as an activity in a Learning Management System (LMS) i.e. Moodle.
It should NOT be a repository where you can pick or link files from ownCloud to the LMS.
It should be an activity where you can share files or work in files collaboratively i.e. collabora.
Therefore authentication an context should be handed over from the LMS to ownCloud. One way to do this could be via Learning Tools Interoperabilit LTI.
Are there any plans to implement LTI in ownCloud or are there other possibilities to realize the use case above?
