Mabugs
October 14, 2021, 4:13pm
1
How can install onlyoffice document server on the same machine with owncloud?
cortho
October 15, 2021, 10:43am
2
Hi Mabugs,
If you are not too deep in Linux/ownCloud/Onlyoffice internals probably the easiest solution is using the appliance - see ONLYOFFICE Document Server with ownCloud as an Appliance - there should be enough documentation on the web.
An alternate way would be proxying the Onlyoffice services or have them listening to other ports. Documentation is found at ONLYOFFICE Api Documentation - ownCloud ONLYOFFICE integration app .
Mabugs
October 15, 2021, 8:16pm
3
Hi cortho ,
Thanks for your response. However what i was asking is how to install owncloud and onlyoffice on the same host?
Mabugs
October 17, 2021, 3:04pm
4
Actually this answered all my questions
OnlyOffice on the same server as Nextcloud
This document explains how to install OnlyOffice on the same server as Nextcloud, with this configuration
- Debian/Apache
- Nextcloud
- OnlyOffice (Docker version, Document Server only) behind a proxy
- Let's encrypt for everything
Required specifications
- Apache2
- A working Nextcloud Instance with SSL
- Docker installed (see https://docs.docker.com/engine/install/)
- Let's encrypt (certbot) installed (see https://certbot.eff.org/instructions)
The examples below are working for Debian 10 Buster. Some modifications might be required for a different system. The URL used in this example are:
This file has been truncated. show original
cortho
October 18, 2021, 10:23am
5
which is exactly what I wrote in my second paragraph and what you found as your solution. If you had been more verbose in your original post you would have gotten preciser answers.
system
Closed
January 16, 2022, 10:23am
6
