OIDC login completes successfully.
Authentik successfully returns the authorization code,
/tokenreturns200, and/userinforeturns200. -
ownCloud Android successfully calls
/ocs/v2.php/cloud/user?format=jsonand receives200. -
After successful authentication, the app never loads the file list.
No further WebDAV requests are made.
Uploads remain stuck in
TRANSFER_QUEUED/TRANSFER_IN_PROGRESS. -
The Android log repeatedly stops at:
SingleSessionManager: getClientFor starting OwnCloudClient: Creating OwnCloudClient AccountUtils: Trying to retrieve credentials for oAuth account... -
The same behaviour occurs with ownCloud Android 4.8.3 and 4.8.4 beta, and with oCIS 8.0.8 and 8.2.0.
- After successful OIDC authentication, the app should load the remote file list and allow uploads/downloads normally.
Configure oCIS with Authentik as the OIDC provider.
Connect using ownCloud Android 4.8.3 or 4.8.4.
Complete the OIDC login successfully.
Open the file list or start an upload.
Can this problem be reproduced with the official owncloud server?
(url: https://demo.owncloud.org, user: test, password: test)
The same Android device and the same ownCloud app also fail to connect to the official ownCloud demo server (https://demo.owncloud.org) with an SSL connection error.
Environment data
Android version: 16
Device model: SM-S926B/DS (Galaxy S24+)
Stock or customized system: Stock One UI 8.5
ownCloud app version: 4.8.3/4.8.4 beta (tried both)
ownCloud server version: 8.0.8/.8.2.0 (tried both)
no server errors
D: 2026-09-02 15:12:37:311(FileDisplayActivity.kt:382)Initializing Fragments in onAccountChanged..
D: 2026-09-02 15:12:37:313(SingleSessionManager.java:98)getClientFor starting
I: 2026-09-02 15:12:37:313(AccountUtils.java:115)Trying to retrieve credentials for oAuth accountmikko@ocis.domain.com
E: 2026-09-02 15:12:37:312(FileDisplayActivity.kt:450)Still have a chance to lose the initialization of list fragment >(
D: 2026-09-02 15:12:37:314(SingleSessionManager.java:98)getClientFor starting
D: 2026-09-02 15:12:37:315(OwnCloudClient.java:97)#24Creating OwnCloudClient
I: 2026-09-02 15:12:37:315(AccountUtils.java:115)Trying to retrieve credentials for oAuth accountmikko@ocis.domain.com
D: 2026-09-02 15:12:37:315(OwnCloudClient.java:97)#25Creating OwnCloudClient
The client repeatedly stops after:
"Trying to retrieve credentials for oAuth account..."
No subsequent WebDAV request is made.
