Owncloud appliance installation
Hello, so I imported the owncloud appliance onto virtualbox. I am going through installation steps and for some reason, it stays stuck at the hosting settings. Next button just spins but does not move on to next step. I have left the domain it chose for me. Does anyone know how to fix this?
