1.Go to hostname
2.
3.
Login Prompt
https://imgur.com/0jbt1Nv This page appears
Operating system: Ubuntu 14.05 -> 16.05
Web server: Apache2
PHP version: 5.x -> 7.0.30
ownCloud version: 8.x -> 10.0.9
Updated from an older ownCloud or fresh install: From 8.0
Where did you install ownCloud from: Owncloud Stable Repository
Signing status (ownCloud 9.0 and above): Has a let’s encrypt cert and can get to secure https page
<?php
$CONFIG = array (
'instanceid' => 'oc5j8p6a1x5a',
'passwordsalt' => 'removed',
'secret' => 'removed',
'trusted_domains' =>
array (
0 => 'localhost',
1 => 'removed',
2 => 'removed',
'datadirectory' => '/var/www/owncloud/data',
'overwrite.cli.url' => 'removed',
'dbtype' => 'mysql',
'version' => '8.2.3.2',
'dbname' => 'oc',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'dbuser' => 'oc_admin',
'dbpassword' => 'removed',
'logtimezone' => 'UTC',
'installed' => true,
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'removed',
'mail_domain' => 'removed',
'mail_smtphost' => 'removed',
'mail_smtpport' => '25',
'memcache.local' => '\\OC\\Memcache\\Redis',
'filelocking.enabled' => 'true',
'memcache.distributed' => '\\OC\\Memcache\\Redis',
'Redis' =>
array (
'host' => 'localhost',
'port' => 6379,
'timeoute' => 0,
'dbindex' => 0,
'appstore.experimental.enabled' => false,
'maintenance' => false,
'theme' => '',
'loglevel' => 0,
'mail_smtpsecure' => 'tls',
'ldapIgnoreNamingRules' => false,
Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/owncloud/lib/private/DB/Connection.php:62
Stack trace:
#0 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /var/www/owncloud/lib/private/DB/Connection.php(145): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#6 /var/www/owncloud/lib/private/DB/ConnectionFactory.php(145): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#7 /var/www/owncloud/lib/private/Server.php(526): OC\DB\ConnectionFactory->getConnection('mysql', Array)
#8 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#9 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet('DatabaseConnect...')
#10 /var/www/owncloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query('DatabaseConnect...')
#11 /var/www/owncloud/lib/private/Server.php(1211): OC\ServerContainer->query('DatabaseConnect...')
#12 /var/www/owncloud/lib/private/Server.php(402): OC\Server->getDatabaseConnection()
#13 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#14 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet('AppConfig')
#15 /var/www/owncloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query('AppConfig')
#16 /var/www/owncloud/lib/private/Server.php(1140): OC\ServerContainer->query('AppConfig')
#17 /var/www/owncloud/lib/private/Server.php(580): OC\Server->getAppConfig()
#18 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC\{closure}(Object(OC\Server))
#19 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet('AppManager')
#20 /var/www/owncloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query('AppManager')
#21 /var/www/owncloud/lib/private/Server.php(1410): OC\ServerContainer->query('AppManager')
#22 /var/www/owncloud/lib/private/legacy/app.php(346): OC\Server->getAppManager()
#23 /var/www/owncloud/lib/private/legacy/app.php(110): OC_App::getEnabledApps()
#24 /var/www/owncloud/lib/base.php(586): OC_App::loadApps(Array)
#25 /var/www/owncloud/lib/base.php(1004): OC::init()
#26 /var/www/owncloud/console.php(64): require_once('/var/www/ownclo...')
#27 /var/www/owncloud/occ(11): require_once('/var/www/ownclo...')
List of activated apps: None
Stack trace:
#7 /var/www/owncloud/lib/private/Server.php(526): OC\DB\ConnectionFactory->getConnection(‘mysql’, Array)
#8 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#9 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘DatabaseConnect…’)
#10 /var/www/owncloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘DatabaseConnect…’)
#11 /var/www/owncloud/lib/private/Server.php(1211): OC\ServerContainer->query(‘DatabaseConnect…’)
#13 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#14 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘AppConfig’)
#15 /var/www/owncloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘AppConfig’)
#16 /var/www/owncloud/lib/private/Server.php(1140): OC\ServerContainer->query(‘AppConfig’)
#18 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#19 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘AppManager’)
#20 /var/www/owncloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘AppManager’)
#21 /var/www/owncloud/lib/private/Server.php(1410): OC\ServerContainer->query(‘AppManager’)
#26 /var/www/owncloud/console.php(64): require_once(’/var/www/ownclo…’)
#27 /var/www/owncloud/occ(11): require_once(’/var/www/ownclo…’)
Are you using external storage, if yes which one: Local
Are you using encryption: No (just SSL)
Browser: Chrome
Operating system: Windows 10
Uhhhh....
Doesn't exsist
Uhhhh....
