Having more than one virtual folder inside each other
if my “downloads” folder has a virutal folder like “downloads/compressed” I get a warning if I try to make a “virtual” folder for just “downloads” (if I create downloads/compressed first).
- Create a virtual folder inside your downloads folder on PC
- Try to create a new virtual folder at the root folder of your previous virtual folder
- You’ll get a warning that you can’t create a virtual folder where an existing virtual folder exists in a LEVEL UP. E.G. downloads/compressed, if you try to make one for just “downloads” where there is a virtual folder for “downloads/compressed”.
ownCloud version: 10.4.0.4
Storage backend (external storage): Google Drive
Client version: 2.6.1
Operating system: Windows 10
OS language: English
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile ) -
Web server error log:
