Just updated the centos client 2.3.0, but getting always unknown error
Upgrade centos desktop clien to 2.3.0
Sync with server
Expected to sync around 1.5 GB of Data
Getting Error like “unknown Error” and getting lost connection to the server.
When tried to “force sync” it works for few files but again got interrupted. The issue continues inconsistently.
But in windows client, same data from same server synced without any issues.
Client version: 2.3.0
Client operating system:
Centos 6.5
Operating system: Centos 6.5
Web server: Apache/2.2.15 (Unix)
Database: MariaDB
PHP version: v5.6.3
if that happends after an update of the client then please report that directly to the sync client developers at [1].
[1]
Thank you for the response. Just Done.
Thanks. Here is the reference if some one else is stumbling over the same issue:
opened 09:22AM - 12 Mar 17 UTC
closed 07:17AM - 09 May 17 UTC
Needs info
Just updated the centos client 2.3.0, but getting always unknown error and conne… ction lost
### Expected behaviour
### Actual behaviour
Getting Error like "unknown Error" and getting lost connection to the server.
When tried to "force sync" it works for few files but again got interrupted. The issue continues inconsistently.
### Steps to reproduce
1. Upgrade centos desktop centos client to 2.3.0
2. Sync with server
### Server configuration
Database: MariaDB SQL
PHP version: PHP 5.6.30
ownCloud version: 9.1.4
Storage backend (external storage): Yes
### Client configuration
Operating system: Centos 6.8
OS language: English
Client package (From ownCloud or distro) (Linux only): Distro
Installation path of client: /usr/bin/owncloud
### Logs
03-12 14:50:50:183 0xf56340 virtual OCC::BandwidthManager::~BandwidthManager()
03-12 14:50:50:184 0xf56340 - client version 2.3.0 Qt 4.8.6
03-12 14:50:50:185 0xf56340 -> SyncEngine finished with ERROR
03-12 14:50:50:201 0xf56340 OO folder slotSyncFinished: result: 3
03-12 14:50:50:202 0xf56340 * owncloud csync thread finished with error
03-12 14:50:50:202 0xf56340 the last 12 syncs failed
03-12 14:50:50:202 0xf56340 Sync state changed for folder "https://g4m-phx.dyndns.org:1011/owncloud/remote.php/webdav/" : "Error"
03-12 14:50:50:403 0xf56340 <===================================== sync finished for "https://g4m-phx.dyndns.org:1011/owncloud/remote.php/webdav/"
03-12 14:51:11:987 0xf56340 # Check whether authenticated propfind works.
03-12 14:51:11:988 0xf56340 !!! OCC::PropfindJob created for "https://g4m-phx.dyndns.org/owncloud" + "/" "OCC::ConnectionValidator"
03-12 14:51:14:798 0xf56340 !!! OCC::PropfindJob created for "https://g4m-phx.dyndns.org/owncloud" + "/" "OCC::QuotaInfo"
03-12 14:51:15:790 0xf56340 Saving account "https://g4m-phx.dyndns.org:1011/owncloud"
03-12 14:51:15:791 0xf56340 Saving 1 unknown certs.
03-12 14:51:15:792 0xf56340 Saving cookies. "/home/sridhar/.local/share/data//ownCloud//cookies0.db"
03-12 14:51:15:793 0xf56340 "/home/sridhar/.local/share/data//ownCloud//cookies0.db"
03-12 14:51:15:794 0xf56340 Saved account settings, status: 0
03-12 14:51:28:298 0xf56340 * Trying to check "https://g4m-phx.dyndns.org:1011/owncloud/remote.php/webdav/" for changes via ETag check. (time since last sync: 38 s)
03-12 14:51:28:299 0xf56340 Scheduling "https://g4m-phx.dyndns.org:1011/owncloud/remote.php/webdav/" to check remote ETag
03-12 14:51:28:299 0xf56340 !!! OCC::RequestEtagJob created for "https://g4m-phx.dyndns.org/owncloud" + "/" "OCC::Folder"
1. Client logfile:
[owncloud-clent-2.3.0-log.txt](https://github.com/owncloud/client/files/836404/owncloud-clent-2.3.0-log.txt)
