OwnCloud client for Raspbian
N/A
N/A
Operating system: N/A
Web server: N/A
Database: N/A
PHP version: N/A
ownCloud version: N/A
Storage backend (external storage): N/A
Client version: ?
Operating system: Raspbian
OS language: ?
Qt version used by client package (Linux only, see also Settings dialog): ?
Client package (From ownCloud or distro) (Linux only): ?
Installation path of client: ?
logs.
  1. Client logfile: Output of owncloud --logwindow or owncloud --logfile log.txt
    (On Windows using cmd.exe, you might need to first cd into the ownCloud directory)
    (See also ownCloud Documentation Overview :: Documentation for ownCloud (A Kiteworks Company) )
  2. Web server error log: ?
  3. Server logfile: ownCloud log (data/owncloud.log): ?
From what i know there is no client for raspbian offered by the owncloud team.
How about Ubuntu Mate?
Just browse to Download Server Packages - ownCloud which redirects you too Install package isv:ownCloud:desktop / owncloud-client On that page you see the supported linux distributions, maybe one of the listed there is also working on Mate.
ok, i tried apt install owncloud-client and everything is ok… thanks
