The client should stay online and stay sync’d
The client randomly disconnects (times can vary from minutes to hours) with an error "Server https://server.company.com is temporarily unavailable
Login.
Wait.
Operating system: Ubuntu 18.0.4
Web server: Apache2
Database: mysql
PHP version: 7.2
ownCloud version: 10.5.0.10
Storage backend (external storage): smb (Apple and Synology NAS)
Client version: 10.15
Operating system: MacOS
OS language: English
Qt version used by client package (Linux only, see also Settings dialog): N/A
Client package (From ownCloud or distro) (Linux only): N/A
Installation path of client: /Users/Applications
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory) -
Web server error log: [Mon Sep 28 06:25:13.381915 2020] [mpm_prefork:notice] [pid 1796] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured – resuming normal operations
[Mon Sep 28 06:25:13.381941 2020] [core:notice] [pid 1796] AH00094: Command line: ‘/usr/sbin/apache2’
[Mon Sep 28 15:37:22.722791 2020] [mpm_prefork:notice] [pid 1796] AH00171: Graceful restart requested, doing restart
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.1.1. Set the ‘ServerName’ directive globally to suppress this message
[Mon Sep 28 15:37:22.863616 2020] [mpm_prefork:notice] [pid 1796] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured – resuming normal operations
[Mon Sep 28 15:37:22.863634 2020] [core:notice] [pid 1796] AH00094: Command line: ‘/usr/sbin/apache2’
[Mon Sep 28 15:37:29.974502 2020] [mpm_prefork:notice] [pid 1796] AH00171: Graceful restart requested, doing restart
[Mon Sep 28 15:37:30.069139 2020] [mpm_prefork:notice] [pid 1796] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured – resuming normal operations
[Mon Sep 28 15:37:30.069165 2020] [core:notice] [pid 1796] AH00094: Command line: ‘/usr/sbin/apache2’
[Mon Sep 28 15:37:33.115370 2020] [mpm_prefork:notice] [pid 1796] AH00171: Graceful restart requested, doing restart
[Mon Sep 28 15:37:33.185415 2020] [mpm_prefork:notice] [pid 1796] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured – resuming normal operations
[Mon Sep 28 15:37:33.185433 2020] [core:notice] [pid 1796] AH00094: Command line: ‘/usr/sbin/apache2’
[Tue Sep 29 06:25:06.409884 2020] [mpm_prefork:notice] [pid 1796] AH00171: Graceful restart requested, doing restart
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.1.1. Set the ‘ServerName’ directive globally to suppress this message -
Server logfile: ownCloud log (data/owncloud.log): (Log file is 68M)
EXTRA INFO
Most users don’t have this issue, but the affected owner is synchronising 5.8TB of files. These are media files and many of them. The issue occurs on any client computer that logs in as this user.
Can’t put lines in from client log as they contain links and these are not allowed from me as I am a new poster.
I should mention too that Owncloud is authenticationg using LDAP to an Apple server running OpenDirectory. I suspect this is where the problems are arising.
