De volgende pakketten hebben niet-voldane vereisten:
owncloud-client : Vereisten: libowncloudsync0 (= 2.4.0-8911) but it wont be installed
Vereisten: ocqt562+240-libqt5core5a but it wont be installed
Vereisten: ocqt562+240-libqt5dbus5 but it wont be installed
Vereisten: ocqt562+240-libqt5gui5 but it wont be installed
Vereisten: ocqt562+240-libqt5keychain1 but it wont be installed
Vereisten: ocqt562+240-libqt5network5 but it wont be installed
Vereisten: ocqt562+240-libqt5webkit5 but it wont be installed
Vereisten: ocqt562+240-libqt5widgets5 but it wont be installed
Vereisten: ocqt562+240-libqt5xml5 but it wont be installed
Vereisten: owncloud-client-l10n but it wont be installed
Vereisten: ocqt562+240-libqt5sql5-sqlite but it wont be installed
If i want to install the downloaded owncloud-client desktop in linux mint i got the error
error: dependence is not fulfillable libowncloudsync0 (=2.4.0-8911)
When i install owncloud-client with the command apt-get install owncloud-client and i start the application and fill in the site username and password i got
Yes. I’ve always used it. But since updating our server to 10.0.6 it was requiring the newest version, which I can’t install.
This errors I’ve received by installing with apt:
sudo apt-get install owncloud-client
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
owncloud-client : Depends: libowncloudsync0 (= 2.4.0-8911) but 2.1.1+dfsg-1ubuntu1.1 is to be installed
Depends: ocqt562+240-libqt5core5a but it is not going to be installed
Depends: ocqt562+240-libqt5dbus5 but it is not going to be installed
Depends: ocqt562+240-libqt5gui5 but it is not going to be installed
Depends: ocqt562+240-libqt5keychain1 but it is not going to be installed
Depends: ocqt562+240-libqt5network5 but it is not going to be installed
Depends: ocqt562+240-libqt5webkit5 but it is not going to be installed
Depends: ocqt562+240-libqt5widgets5 but it is not going to be installed
Depends: ocqt562+240-libqt5xml5 but it is not going to be installed
Depends: ocqt562+240-libqt5sql5-sqlite but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
