ownCloud client not synchronizing
  1. Modify file on computer 1
  2. Modified file is synchronized with server
  3. Verify if modified file is downloaded from server on computer 2
File should automatically get modified on computer 2, same as the change should be shown on the sync protocol of computer 2
File does not get modified on computer 2, although the client recognizes that the change has been made on the server (Server activity)
Ubuntu Linux 16.04.3
Apache2
MySQL
10.0.4
Updated
Owcloud repositories
    "system": {
        "updatechecker": false,
        "instanceid": "***REMOVED SENSITIVE VALUE***",
        "files_external_allow_create_new_local": "true",
        "trusted_domains": [
        "overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
        "dbtype": "mysql",
        "version": "10.0.4.4",
        "dbname": "owncloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "logtimezone": "UTC",
        "installed": true,
        "theme": "",
        "loglevel": 2,
        "maintenance": false,
        "memcache.locking": "\\OC\\Memcache\\APCu"
Enabled:
  - activity: 2.3.6
  - calendar: 1.5.4
  - comments: 0.3.0
  - configreport: 0.1.1
  - contacts: 1.5.3
  - dav: 0.3.2
  - federatedfilesharing: 0.3.1
  - federation: 0.1.0
  - files: 1.5.1
  - files_antivirus: 0.11.2
  - files_external: 0.7.1
  - files_external_dropbox: 1.0.0
  - files_pdfviewer: 0.8.2
  - files_sharing: 0.10.1
  - files_texteditor: 2.2.1
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - firstrunwizard: 1.1
  - market: 0.2.3
  - notifications: 0.3.2
  - provisioning_api: 0.5.0
  - systemtags: 0.3.0
  - updatenotification: 0.2.1
Disabled:
  - encryption
  - external
  - files_videoplayer
  - gallery
  - oauth2
  - templateeditor
  - theme-example
  - user_external
local
no
Firefox
Ubuntu 16.04
No error logs
Note
Could it be that is is due to having used the following mysql-command?:
UPDATE oc_filecache
SET checksum = ''
WHERE COALESCE (checksum, '') <> ''
in order to get rid of the following annoying malfunction:
Certain files would not be downloaded from the sever, showing the following message on the client’s ‘Not Synced’ tab:
The Downloaded File does not match the checksum, the download will be resumed
Let me quote myself from another place:
Modifying the DB manually is untested, unsupported and with unknown consecuences. Basically, use it at your own risk.
I’m not sure if that can be “auto-repaired” by uploading a new version of the files.
For the checksum problem, check that the uploaded file is the same in the client 1 (the one that uploaded the file) and the server. You can do it by opening the file or via checksum.
You can also check the same for the download, using another client.
I reinstalled the server and resynchronized all my files. Now it’s working again.
