Have an OwnCloud server at BananaPI. Got some problem with the hard drive and did not use it for a while. After runing fsck and solving the issue with the file system the OwnCloud came back to life. Can connect via Web and via Windows client and see the content. The Windows client is "Chacking for changes, go through some files and then closes in about 1,5 min. Then starts all over again (though seems like it is checking other files). In the Activity section there are status masseges “Aborted” exactly 2 min apart. Updated the owncloud server to 10.10 (from 9.3.ish) and php from 7.2 to 7.4 but still the same. Newest version of the client.
1.Login to Windows client
2.Sync is started automatically
3. Wait for the error
Sync without error
Stops with an error every 2 min, then restarts again
root@bananapi:/var/www/owncloud# uname -a
Linux bananapi 5.15.43-sunxi #22.05.1 SMP Sat May 28 08:17:47 UTC 2022 armv7l GNU/Linux
apache2
mysql
10.10
not related, recently updated but problem persisted even before
stable release download
"system": {
"updatechecker": false,
"instanceid": "oc2ogdrm8g13",
"trusted_domains": [
"192.168.0.154",
TWO MORE DOMAINS
"datadirectory": "\/media\/hdd\/owncloud_files",
"overwrite.cli.url": "http:\/\/192.168.0.154",
"dbtype": "mysql",
"version": "10.10.0.3",
"memcache.local": "\\OC\\Memcache\\Redis",
"redis": {
"host": "localhost",
"port": 6379
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/apps-external",
"writable": true
"installed": true,
"updater.secret": "***REMOVED SENSITIVE VALUE***",
"maintenance": false,
"loglevel": 2,
"allow_user_to_change_mail_address": ""
Firefox
Windows 10
{"reqId":"YrIy@jJd@1ZBbZdp5NW4QgAAAAo","level":0,"time":"2022-06-21T21:07:06+00:00","remoteAddr":"192.168.0.248","user":"mal_ownCloud","app":"OC\\User\\Session::validateToken","method":"POST","url":"\/index.php\/settings\/admin\/log\/level","message":"token c003860a7b638ac4c3e64e1f0833a3c07cb78e04d9239522e59e041eeb5ce6242a2df3a6a9ba2a5b0525ee90baa4f425325a8b316d850fbd83e55f2381c22ccf with token id 561 found, validating"}
{"reqId":"YrIy@jJd@1ZBbZdp5NW4QgAAAAo","level":0,"time":"2022-06-21T21:07:07+00:00","remoteAddr":"192.168.0.248","user":"mal_ownCloud","app":"OC\\User\\Session::validateToken","method":"POST","url":"\/index.php\/settings\/admin\/log\/level","message":"token c003860a7b638ac4c3e64e1f0833a3c07cb78e04d9239522e59e041eeb5ce6242a2df3a6a9ba2a5b0525ee90baa4f425325a8b316d850fbd83e55f2381c22ccf with token id 561 found, validating"}
{"reqId":"2ddc2f88-c964-4d1a-b7f4-dff192200cb2","level":0,"time":"2022-06-21T21:07:07+00:00","remoteAddr":"192.168.0.1","user":"mal_ownCloud","app":"OC\\Authentication\\Token\\DefaultTokenProvider::updateToken","method":"PROPFIND","url":"\/remote.php\/dav\/files\/mal_ownCloud\/Personal\/hobby\/planes\/Sonerai\/Flash%20drive%20OH-XPW\/Sonerai%20Files\/Sonerai%20aeroplane%20hood\/P1180020.JPG","message":"updating token 569, last check is now 1655845538"}
{"reqId":"2ddc2f88-c964-4d1a-b7f4-dff192200cb2","level":0,"time":"2022-06-21T21:07:07+00:00","remoteAddr":"192.168.0.1","user":"mal_ownCloud","app":"OC\\Authentication\\Token\\DefaultTokenProvider::getToken","method":"PROPFIND","url":"\/remote.php\/dav\/files\/mal_ownCloud\/Personal\/hobby\/planes\/Sonerai\/Flash%20drive%20OH-XPW\/Sonerai%20Files\/Sonerai%20aeroplane%20hood\/P1180020.JPG","message":"token 8070378a14c18063543cb424578001a1a8aed82b82734b670d803344018605d00bfb3a5918c76f430c258cef8bf54bb7a37bd2f7ffed77bf8ca3cc6c73e90d8a does not exist"}
{"reqId":"7aca5675-3990-4d13-bc4a-9a2323e745c0","level":0,"time":"2022-06-21T21:07:08+00:00","remoteAddr":"192.168.0.1","user":"mal_ownCloud","app":"OC\\Authentication\\Token\\DefaultTokenProvider::updateToken","method":"PROPFIND","url":"\/remote.php\/dav\/files\/mal_ownCloud\/Personal\/hobby\/planes\/Sonerai\/Flash%20drive%20OH-XPW\/Sonerai%20Files\/Sonerai%20aeroplane%20hood\/P3210032.JPG","message":"updating token 569, last check is now 1655845538"}
{"reqId":"7aca5675-3990-4d13-bc4a-9a2323e745c0","level":0,"time":"2022-06-21T21:07:08+00:00","remoteAddr":"192.168.0.1","user":"mal_ownCloud","app":"OC\\Authentication\\Token\\DefaultTokenProvider::getToken","method":"PROPFIND","url":"\/remote.php\/dav\/files\/mal_ownCloud\/Personal\/hobby\/planes\/Sonerai\/Flash%20drive%20OH-XPW\/Sonerai%20Files\/Sonerai%20aeroplane%20hood\/P3210032.JPG","message":"token 8070378a14c18063543cb424578001a1a8aed82b82734b670d803344018605d00bfb3a5918c76f430c258cef8bf54bb7a37bd2f7ffed77bf8ca3cc6c73e90d8a does not exist"}
{"reqId":"ce4af1df-09cb-4f78-9707-5a4eb644b615","level":0,"time":"2022-06-21T21:07:09+00:00","remoteAddr":"192.168.0.1","user":"mal_ownCloud","app":"OC\\Authentication\\Token\\DefaultTokenProvider::updateToken","method":"PROPFIND","url":"\/remote.php\/dav\/files\/mal_ownCloud\/Personal\/hobby\/planes\/Sonerai\/Flash%20drive%20OH-XPW\/Sonerai%20Files\/Sonerai%20aeroplane%20hood\/P3210033.JPG","message":"updating token 569, last check is now 1655845538"}
{"reqId":"ce4af1df-09cb-4f78-9707-5a4eb644b615","level":0,"time":"2022-06-21T21:07:09+00:00","remoteAddr":"192.168.0.1","user":"mal_ownCloud","app":"OC\\Authentication\\Token\\DefaultTokenProvider::getToken","method":"PROPFIND","url":"\/remote.php\/dav\/files\/mal_ownCloud\/Personal\/hobby\/planes\/Sonerai\/Flash%20drive%20OH-XPW\/Sonerai%20Files\/Sonerai%20aeroplane%20hood\/P3210033.JPG","message":"token 8070378a14c18063543cb424578001a1a8aed82b82734b670d803344018605d00bfb3a5918c76f430c258cef8bf54bb7a37bd2f7ffed77bf8ca3cc6c73e90d8a does not exist"}
Missing at /var/www/owncloud/data
Not relevant
