Steps to reproduce 1. Use lastest version app on iPad 9.3.5 2. 3.
Expected behaviour working normally Actual behaviour Tell us what happens instead Connection could not be established Mobile client configuration Client OS (iOS Client version: 9.3.5 Server configuration Operating system: Web server: linux Database: PHP version: ownCloud version (see ownCloud admin page): 8.1.9 Updated from an older ownCloud or fresh install: ownCloud log (data/owncloud.log):
This sentence makes no sense. You already can't connect from the app as you have written in your initial post. Please clarify or be a little bit more precise...
I m connected, and get a list of files ready do be syncronized. But when I touch the file in order to get it on myiPad I get the message cannot connect to the server. Problem is only on my ipad . on Windows and via web browser it works
Do you use wifi in your home network? Or a mobile connection? Can you access via webinterface (on your webbrowser) on your iPad? Can you see anything in your logfiles, for example a permission denied?
Can you connect the client on your iPad to demo.owncloud.org (user/pw: test/test)?
