Hi everyone,
I installed on cPanel a plugging with softaculous, inside softaculous i installed owncloud.
All the application works fine but I’m unuable to connect with the application from windows device,
I attached an example what I did, do you know if I need to add any console conmmand or is it a kind of bug?
Im unable with Webdav,
Anybody know how to solve this? is it possibl eto use with shared hosting?
Its probably better to use a vserver without cpanel/softaculous.
dnoe
4
It has to be something with the server and/or host. I’ve installed owncloud via softaculous without any problems.
Look into the servers configuration settings, like the versions of PHP and such.
