Hi everyone,
We have released the ownCloud Desktop Client 2.10.0.
Downloads are available on The Desktop App for efficient syncing - ownCloud
Changelog for ownCloud Desktop Client 2.10.0
Summary
- Bugfix - Issues with long file path: #4896
- Bugfix - Do not ask for credentails at start-up when the user logged out: #8924
- Bugfix - A folder moved on the server was displayed as outdated: #9071
- Bugfix - Immediately propagate changes to the ignore list: #8975
- Bugfix - Fix icon name in desktop file with ownBrander themes: #8992
- Bugfix - Crash when handling locked files: #9170
- Bugfix - Don’t abort upload if chunk is locked: #9194
- Bugfix - Always restart OAuth2 on error: #9196
- Bugfix - Display correct error message for files containign
\:?*"<>|: #9223 - Bugfix - Do not sync when unsyncedfolders file cannot be read: #9165
- Bugfix - Fix failing dehydration causing files to be moved to trash: #9257
- Bugfix - Do not show Activity tab if server app is disabled or uninstalled: #9260
- Bugfix - Handle file locks for delete jobs: #9293
- Bugfix - Run a full local discovery after we where paused or on a forced sync: #9341
- Bugfix - Infinite sync loop if folder is locked: #9342
- Bugfix - We fixed a possible crash: #13
- Enhancement - Reintroduce issue filtering: #9000
- Enhancement - Allow to remove broken sync folders: #9099
- Enhancement - Also ignore local reapeating errors for a period of time: #9208
- Enhancement - Remove the availability menu from the ui: #9291
- Enhancement - Add the syncroot to the search indexed with Windows VFS: #12
Have fun!
