Hi everyone,
We have released the ownCloud Desktop Client 2.10.1.
Downloads are available on The Desktop App for efficient syncing - ownCloud
Changelog for ownCloud Desktop Client 2.10.1
Summary
- Bugfix - Do not strip trailing whitespace from a file or folder name: #9030
- Bugfix - Remove outdated translations: #9105
- Bugfix - Progress reporting for TUS uploads: #9121
- Bugfix - Fix crash if a database error occurs: #9147
- Bugfix - --version showed incorrect information about VFS support: #9155
- Bugfix - Client warns about non exisitng files: #9236
- Bugfix - Mention source file in activity tab when renaming: #9238
- Bugfix - Fix crash on remove account: #9367
- Bugfix - Raise ssl issue dialoig above the wizard: #9375
- Bugfix - Fallback to ownCloud sidebar icons on Mac if none provided in branding: #9381
- Bugfix - Immediately retry upload if file changed during sync: #9382
- Bugfix - Don’t reset change time on upload: #9383
- Bugfix - Fix toggling launch-on-login for macOS: #9387
- Bugfix - Fix translated icon names in desktop file with ownBrander themes: #9390
- Bugfix - Fix possible crash: #9417
- Bugfix - Add open local/remote folder options: #9405
- Bugfix - Fix Account Filter for Server Activity tab: #9481
- Bugfix - Ensure proper setup of network jobs on retries: #9437
- Bugfix - If reuqired clear cookies in more scenarios: #9489
- Bugfix - Improve filter pop-up menu and button: #9425
- Bugfix - Possible crash when removing non exisitng folder: #9533
- Bugfix - Can’t stop basic auth login: #9545
- Bugfix - Fix potential download failure for renamed file with Windows VFS: #18
- Bugfix - Possible crash when downloading a virtual file on Windows: #21
- Bugfix - Don’t publish upload if we can’t finish the transaction in the client: #5052
- Enhancement - Retry token refresh multiple times before logout: #9245
- Enhancement - Don’t log error when checking removed file for changes: #9304
- Enhancement - Leave password field in share dialog enabled on errors: #9336
- Enhancement - Provide informal German translations: #9460
- Enhancement - Always flush log when logging to stdout: #9515
- Enhancement - Added branding parameter to disallow duplicated folder sync pairs: #9523
- Enhancement - Retry update after 10 minutes: #9522
Have fun!
