Hi everyone,
We have released the ownCloud Desktop Client 2.9.1.
Downloads are available on The Desktop App for efficient syncing - ownCloud
Changelog for ownCloud Desktop Client 2.9.1
Summary
- Bugfix - Mac multiple dialogs block all input: #8421
- Bugfix - Enforce rtl layout with rtl languages: #8806
- Bugfix - Broken url in branded builds: #8920
- Bugfix - Handle use of directory of another Windows VFS sync client: #8994
- Bugfix - Building libcloudprovider support fails: #8996
- Bugfix - Tables now display local time: #9006
- Bugfix - We fixed a crash when using the retry action on an issue: #9013
- Bugfix - Fix crash when closing the client: #9014
- Bugfix - Crash on missing or unreadable sync root: #9016
- Bugfix - A upgrade to 2.9 causes the usage of a new journal file: #9019
- Bugfix - Properly deployment of Qt translations Mac and Window: #9022
- Bugfix - The file status of suffix placeholders was displayed incorrectly: #9026
- Bugfix - When a folder is removed we leave a database behind: #9057
- Bugfix - Dehydrating placeholders failed if the file is read only: #9093
- Bugfix - Downgrades could trigger deletion of virtual files: #9114
- Enhancement - Display the error type in the issue protocol to allow sorting: #9010
Changelog for ownCloud Desktop Client 2.9.0
Summary
- Bugfix - Settings migration from v2.4: #4597
- Bugfix - VFS support for folders in the drive root: #4639
- Bugfix - Keep share link names in sync with server: #7549
- Bugfix - SQLite wal file grows to several gigabyte: #7646
- Bugfix - Fix missing permission for newly created folder: #8076
- Bugfix - Don’t recommend non default sync option: #8317
- Bugfix - Limit min window size to 2/3 available: #8366
- Bugfix - Set up default locale correctly: #8367
- Bugfix - Ignore consecutive errors for a pereiode of time: #8672
- Bugfix - Properly print the sync events in .owncloudsync.log: #8729
- Bugfix - Correctly handle file path comparison on Windows: #8732
- Bugfix - Locked files are not correctly synced: #8761
- Bugfix - Prompt the user of the cmd client what to do if all files where removed: #8804
- Bugfix - Relaunching the client on macOS will show the settings dialog: #8377
- Bugfix - Fix config migrations from versions 2.8 to 2.9: #8824
- Bugfix - Always exclude .owncloud files: #8836
- Bugfix - Don’t crash if a certain move is undone: #8837
- Bugfix - Prevent sync root sharing: #8849
- Bugfix - Removed support for client side certificates: #8864
- Bugfix - The
Re-open Browsernow always does what it says: #8866 - Bugfix - Start oauth/password prompt if password is wrong during start up: #8901
- Bugfix - Handle timeouts occurring during oauth: #8940
- Change - Don’t ask the user to switch to http: #8231
- Change - Remove support for http redirects: #8293
- Change - We no longer try to locate an ownCloud install at /owncloud: #8273
- Change - Ignore the desktop.ini file in every directory, not only in top dir: #8298
- Change - Add support for dynamic client registration with OIDC: #8350
- Change - Include full os version in the about dialog: #8374
- Change - We removed the support for async jobs using OC-JobStatus-Location: #8398
- Change - Add a branding option to skip the advanced setup page: #8665
- Enhancement - Prefer 127.0.0.1 as oauth redirect url: #4542
- Enhancement - Display an icon in the Windows explorer context menu: #4627
- Enhancement - Show last sync date in tray menu: #5644
- Enhancement - Display the information state in case we encountered ignored errors: #8858
- Enhancement - Make crash report IDs easy to copy: #25
- Enhancement - We reworked the tables: #8158
- Enhancement - Provide a socket api call to get the client icon and: #8464
- Enhancement - Add language picker to general settings: #8466
- Enhancement - Attach the last 20 log lines to a crash report: #8467
- Enhancement - Mention the local file name when a file name clash occurs: #8609
- Enhancement - Consider a remote poll interval coming with the server capabilities: #5947
- Enhancement - Improved handling of errors during local file updates: #8787
- Enhancement - Retry sync on
502 Bad Gateway: #8811
Have fun!
