Hi everyone,
we have released the ownCloud Desktop Client 4.0.0
Downloads are available at The Desktop App for efficient syncing - ownCloud
There are known issues with Fedora 38 installation. Please use AppImage in the meanwhile.
ChangeLog for ownCloud Desktop Client 4.0.0
- Bugfix - Display sync date in system tray context menu when files where ignored: #8953
- Bugfix - Fix computation of sync status when multiple folders are synced: #9270
- Bugfix - Don’t abort local folder deletions on unrelated errors: #9311
- Bugfix - Fix update channel dropdown: #10251
- Bugfix - Select keep files as default action in all files removed dialog: #10254
- Bugfix - Undefined client state after fetching credentials failed: #10408
- Bugfix - Escape navigation elements from user name: #10427
- Bugfix - Under certain conditions the folder watcher could drop events: #10458
- Bugfix - Properly handle OAuth invalidation: #10494
- Bugfix - Clear conflict errors after they where resolved: #10569
- Bugfix - Set the expected download content length in the job properly: #10607
- Bugfix - UI freeze when multiple modal dialogs displayed on macOS: #10621
- Bugfix - Ensure the account state is properly persisted: #10648
- Bugfix - Reconnect got stuck if the server supports app providers: #10666
- Change - Implement server guided migration to spaces: #9945
- Enhancement - Display
This space is either disabled or deletedfor gone spaces: #9700 - Enhancement - Sync virtual files that are locked by office etc: #9829
- Enhancement - Replace term (un)pause with a more suitable one: #10231
- Enhancement - Check for long paths when these are not enabled on Windows: #10264
- Enhancement - Implement a possibility to Desktop.ini icon updates on Windows: #10361
- Enhancement - Disable DPI scaling factor rounding on Windows: #10406
- Enhancement - Display quota for Spaces: #10453
- Enhancement - New WebFinger workflow: #10517
- Enhancement - Branding: Allow the addition of buttons to open a url: #10518
- Enhancement - Build the client without the auto updater by default: #10537
- Enhancement - Improve presentation of connection state: #10557
- Enhancement - Display open in web in file browser context menu, on sync roots: #10572
- Enhancement - Display space subtitle if available: #10577
- Enhancement - Open sharing options in Web: #10590
- Enhancement - Display the space name provided by the server: #10602
- Enhancement - Always point to the latest documentation: #10634
- Enhancement - More user friendly error handling in the cmd client: #10637
- Enhancement - Don’t invalidate oauth refresh token on ConnectionRefusedError: #10654
Have fun!
