I am using Raspberry pi 1(first version)
OS: Dietpi 6.28
Latest version of owncloud
After I installed owncloud and I type my up with /owncloud but it just show login but I have not even made any admin account
And this is new install
I need help asap!
Welcome to centrral @Damien!
When creating a server issue there is a template that asks for all kinds of details which helps the forum members here help you. So please fill it out.
This I regard as highly offensive. Please, members here are helping in their free time. If you need help so urgently I would recommend you pay for support somewhere.
How did you install? Did you follow some guide?
Usually you are supposed to run the occ maintenance:install command, which also specifies an admin user and password.
Alternatively you should be able to use occ commands to find the admin user and reset its password:
I just installed Dietpi then I install the owncloud and I waited for about an hour
Also when I run something with occ it keeps says it’s not unble to open occ
Operating system
Dietpi running on rpi1
10.4
Fresh install
I installed from Dietpi library
None
Yes u use a USB stick (NTFS) 32gb from SanDisk
I do not know
@eneubauer so I just need to run sudo -u www-data php /var/www/owncloud/occ??
I am sry I am new with this
Is there a guide that i can follow that is step by step?
Read the page I posted, your question is answered there.
Thank you for helping ended up when you install owncloud the default name and password is Admin password is the system password
