<?php
* This code is free software: you can redistribute it and/or modify
* it under the terms of the GNU Affero General Public License, version 3,
* as published by the Free Software Foundation.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Affero General Public License for more details.
* You should have received a copy of the GNU Affero General Public License, version 3,
* along with this program. If not, see <http://www.gnu.org/licenses/>
// Show warning if a PHP version below 5.4.0 is used, this has to happen here
// because base.php will already use 5.4 syntax.
if (version_compare(PHP_VERSION, '5.4.0') === -1) {
echo 'This version of ownCloud requires at least PHP 5.4.0<br/>';
echo 'You are currently running ' . PHP_VERSION . '. Please update your PHP version.';
return;
// Show warning if PHP 7.1 is used as ownCloud is not compatible with PHP 7.1 until
// version 10.0.0.
if (version_compare(PHP_VERSION, '7.1.0') !== -1) {
echo 'This version of ownCloud is not compatible with PHP 7.1.<br/>';
echo 'You are currently running ' . PHP_VERSION . '. Please use at least ownCloud 10.0.0.';
return;
// running oC on Windows is unsupported since 8.1, this has to happen here because
// is seems that the autoloader on Windows fails later and just throws an exception.
if (strtoupper(substr(PHP_OS, 0, 3)) === 'WIN') {
echo 'ownCloud Server does not support Microsoft Windows.';
return;
try {
require_once 'lib/base.php';
OC::handleRequest();
} catch(\OC\ServiceUnavailableException $ex) {
\OC::$server->getLogger()->logException($ex, array('app' => 'index'));
//show the user a detailed error page
OC_Response::setStatus(OC_Response::STATUS_SERVICE_UNAVAILABLE);
OC_Template::printExceptionErrorPage($ex);
} catch (\OC\HintException $ex) {
OC_Template::printErrorPage($ex->getMessage(), $ex->getHint());
} catch (\OC\User\LoginException $ex) {
OC_Response::setStatus(OC_Response::STATUS_FORBIDDEN);
OC_Template::printErrorPage($ex->getMessage());
} catch (Exception $ex) {
OC_Response::setStatus(OC_Response::STATUS_INTERNAL_SERVER_ERROR);
} catch (Error $ex) {
I found this message in index.php.
Please how to upgrade owncloud when is down.
