I need help, i can’t run my owncloud docker.
It keeps restarting.
OwnCloud Version : 10.2.1
Docker Version : 18.09.7, build 2d0083d
OS : Ubuntu 18.04.2 LTS
Here I provide YAML file and Docker Container Log
YAML File
version: ‘2.1’
volumes:
files:
driver: local
mysql:
driver: local
backup:
driver: local
redis:
driver: localservices:
owncloud:
image: owncloud/server:${OWNCLOUD_VERSION}
restart: always
ports:
- ${HTTP_PORT}:8080
depends_on:
- db
- redis
environment:
- OWNCLOUD_DOMAIN=${OWNCLOUD_DOMAIN}
- OWNCLOUD_DB_TYPE=mysql
- OWNCLOUD_DB_NAME=owncloud
- OWNCLOUD_DB_USERNAME=owncloud
- OWNCLOUD_DB_PASSWORD=REMOVED
- OWNCLOUD_DB_HOST=db
- OWNCLOUD_ADMIN_USERNAME=${ADMIN_USERNAME}
- OWNCLOUD_ADMIN_PASSWORD=${ADMIN_PASSWORD}
- OWNCLOUD_MYSQL_UTF8MB4=true
- OWNCLOUD_REDIS_ENABLED=true
- OWNCLOUD_REDIS_HOST=redis
healthcheck:
test: [“CMD”, “/usr/bin/healthcheck”]
interval: 30s
timeout: 10s
retries: 5
volumes:
- files:/mnt/datadb:
image: webhippie/mariadb:latest
restart: always
environment:
- MARIADB_ROOT_PASSWORD=owncloud
- MARIADB_USERNAME=owncloud
- MARIADB_PASSWORD=REMOVED
- MARIADB_DATABASE=owncloud
- MARIADB_MAX_ALLOWED_PACKET=128M
- MARIADB_INNODB_LOG_FILE_SIZE=64M
healthcheck:
interval: 30s
timeout: 10s
retries: 5
volumes:
- mysql:/var/lib/mysql
- backup:/var/lib/backupredis:
image: webhippie/redis:latest
restart: always
environment:
- REDIS_DATABASES=1
healthcheck:
interval: 30s
timeout: 10s
retries: 5
volumes:
- redis:/var/lib/redis
2020-02-17T07:21:01.541829147Z Creating volume folders…
2020-02-17T07:21:01.553124061Z Creating hook folders…
2020-02-17T07:21:01.575379201Z Waiting for MySQL…
2020-02-17T07:21:01.769436795Z Waiting for Redis…
2020-02-17T07:21:02.051202110Z Removing custom folder…
2020-02-17T07:21:02.057635952Z Linking custom folder…
2020-02-17T07:21:02.064262737Z Removing config folder…
2020-02-17T07:21:02.070496815Z Linking config folder…
2020-02-17T07:21:02.077416642Z Writing config file…
2020-02-17T07:21:02.997145740Z Fixing base perms…
2020-02-17T07:21:03.558472459Z Fixing data perms…
2020-02-17T07:21:03.771141330Z Fixing hook perms…
2020-02-17T07:21:04.820997146Z Upgrading server database…
2020-02-17T07:21:05.725405202Z An unhandled exception has been thrown:
2020-02-17T07:21:05.725483706Z ArgumentCountError: Too few arguments to function OCA\User_LDAP\Command\CheckUser::__construct(), 0 passed in /var/www/owncloud/lib/private/Console/Application.php on line 170 and exactly 3 expected in /mnt/data/apps/user_ldap/lib/Command/CheckUser.php:51
2020-02-17T07:21:05.725515309Z Stack trace:
2020-02-17T07:21:05.725538914Z #0 /var/www/owncloud/lib/private/Console/Application.php(170): OCA\User_LDAP\Command\CheckUser->__construct()
2020-02-17T07:21:05.725563356Z #1 /var/www/owncloud/lib/private/Console/Application.php(108): OC\Console\Application->loadCommandsFromInfoXml(Array)
2020-02-17T07:21:05.725589152Z #2 /var/www/owncloud/console.php(105): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
2020-02-17T07:21:05.725615701Z #3 /var/www/owncloud/occ(11): require_once(‘/var/www/ownclo…’)
2020-02-17T07:21:06.819595579Z #4 {main}Writing objectstore config…
2020-02-17T07:21:07.758990105Z Writing php config…
2020-02-17T07:21:09.613241030Z Writing apache config…
2020-02-17T07:21:10.526870261Z Enabling cron background…
2020-02-17T07:21:11.447938254Z An unhandled exception has been thrown:
2020-02-17T07:21:11.448016295Z ArgumentCountError: Too few arguments to function OCA\User_LDAP\Command\CheckUser::__construct(), 0 passed in /var/www/owncloud/lib/private/Console/Application.php on line 170 and exactly 3 expected in /mnt/data/apps/user_ldap/lib/Command/CheckUser.php:51
2020-02-17T07:21:11.448042397Z Stack trace:
2020-02-17T07:21:11.448065676Z #0 /var/www/owncloud/lib/private/Console/Application.php(170): OCA\User_LDAP\Command\CheckUser->__construct()
2020-02-17T07:21:11.448090447Z #1 /var/www/owncloud/lib/private/Console/Application.php(108): OC\Console\Application->loadCommandsFromInfoXml(Array)
2020-02-17T07:21:11.448115068Z #2 /var/www/owncloud/console.php(105): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
2020-02-17T07:21:11.448139830Z #3 /var/www/owncloud/occ(11): require_once(‘/var/www/ownclo…’)
2020-02-17T07:21:11.943155934Z #4 {main}
2020-02-17T07:21:16.779294526Z Creating volume folders…
2020-02-17T07:21:16.799080914Z Creating hook folders…
2020-02-17T07:21:16.836727151Z Waiting for MySQL…
2020-02-17T07:21:17.085999416Z Waiting for Redis…
2020-02-17T07:21:17.285032672Z Writing config file…
2020-02-17T07:21:18.196959719Z Fixing base perms…
2020-02-17T07:21:18.762519505Z Fixing data perms…
2020-02-17T07:21:18.935391798Z Fixing hook perms…
2020-02-17T07:21:20.094649311Z Upgrading server database…
2020-02-17T07:21:21.054234215Z An unhandled exception has been thrown:
2020-02-17T07:21:21.054295426Z ArgumentCountError: Too few arguments to function OCA\User_LDAP\Command\CheckUser::__construct(), 0 passed in /var/www/owncloud/lib/private/Console/Application.php on line 170 and exactly 3 expected in /mnt/data/apps/user_ldap/lib/Command/CheckUser.php:51
2020-02-17T07:21:21.054612813Z Stack trace:
2020-02-17T07:21:21.054630399Z #0 /var/www/owncloud/lib/private/Console/Application.php(170): OCA\User_LDAP\Command\CheckUser->__construct()
2020-02-17T07:21:21.054648590Z #1 /var/www/owncloud/lib/private/Console/Application.php(108): OC\Console\Application-loadCommandsFromInfoXml(Array)
2020-02-17T07:21:21.054667941Z #2 /var/www/owncloud/console.php(105): OC\Console\Application-loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
2020-02-17T07:21:21.054686036Z #3 /var/www/owncloud/occ(11): require_once(‘/var/www/ownclo…’)
2020-02-17T07:21:22.187295201Z #4 {main}Writing objectstore config…
2020-02-17T07:21:23.056788895Z Writing php config…
2020-02-17T07:21:25.019587439Z Writing apache config…
2020-02-17T07:21:26.240799701Z Enabling cron background…
2020-02-17T07:21:27.754681780Z An unhandled exception has been thrown:
2020-02-17T07:21:27.755218360Z ArgumentCountError: Too few arguments to function OCA\User_LDAP\Command\CheckUser::__construct(), 0 passed in /var/www/owncloud/lib/private/Console/Application.php on line 170 and exactly 3 expected in /mnt/data/apps/user_ldap/lib/Command/CheckUser.php:51
2020-02-17T07:21:27.755239504Z Stack trace:
2020-02-17T07:21:27.755256565Z #0 /var/www/owncloud/lib/private/Console/Application.php(170): OCA\User_LDAP\Command\CheckUser->__construct()
2020-02-17T07:21:27.755274204Z #1 /var/www/owncloud/lib/private/Console/Application.php(108): OC\Console\Application-loadCommandsFromInfoXml(Array)
2020-02-17T07:21:27.755292299Z #2 /var/www/owncloud/console.php(105): OC\Console\Application-loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
2020-02-17T07:21:27.755310233Z #3 /var/www/owncloud/occ(11): require_once(‘/var/www/ownclo…’)
2020-02-17T07:21:28.335395036Z #4 {main}
2020-02-17T07:21:33.027864652Z Creating volume folders…
2020-02-17T07:21:33.036871783Z Creating hook folders…
2020-02-17T07:21:33.080611741Z Waiting for MySQL…
and keeps going on like that…
I didn’t made any changes since upgrading to 10.2.1, there’s blackout a few days ago and now this happens
Thank you in advance
