I have an ownCloud server (Docker) running.
I mounted my /home
directories as volumes. I can see them attach them as Local
storage. The only issue I’m experiencing is, it doesn’t have correct permission to write on the existing /home
directories. I created a new directory with www-data
and it works. Is there any possibility to NOT
change the owners to www-data
and use root
instead?
i’m not sure if this is an ownCloud specific question or if this is more related to Docker and thus could be maybe require to be placed into a Docker support forum.
