1. Pull down the latest owncloud docker image: https://hub.docker.com/_/owncloud/
2. Pull down the latest mysql docker image: https://hub.docker.com/_/mysql/
3. Create and run the mysql container
4. Create and run the owncloud container and link it to the mysql container (had to mount a directory for /tmp to prevent large file upload issues, since it looks like files are stored here during upload):
docker run -d --name owncloud --link mysql:mysql -v /share/owncloud-home/html:/var/www/html -v /share/owncloud-home/tmp:/tmp -p 9080:80 owncloud:latest
5. Create an admin account and log into owncloud
6. Upload a large (3gb+) file
The file should be uploaded into owncloud correctly
Sometimes, it says the upload failed, and the page is forced to refresh. Sometimes the upload status bar slowly reached the end, but nothing happens for the next hour.
Operating system: Linux (via Docker)
Web server: Apache (via Docker)
PHP version: 7 (via Docker)
ownCloud version (see ownCloud admin page): latest
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): whatever came with the Docker image
N/A
Integrity status for oC9+
N/A
