- ownCloud 10.5.0 run as docker service
- external mySQL 5.7 database
- /mnt/data from container mounted on GlusterFS volume on host
While ownCloud files are located on GlusterFS volume, after login I can see list of files.
After login ownCloud interface is loaded, but there is loader image instead of files list. Firefox network console say that there is no response to /remote.php/dav/files/admin/. Requestes is still waiting, no any http error. Response is 0 bytes.
On volume in docker host, default files are created and exists in /files/admin/files.
After switching LOG_LEVEL to DEBUG owncloud.log didn’t indicate to any errors.
In UI admin -> Settings is also stucking on loader, docker desktop client is starting synchronization but is unable to get any files.
Switching mount of /mnt/data to standard filesystem directory (instead of GlusterFS volume) resolves any problems.
Ubuntu server 18.04
Docker 19.03.12 in swarm mode
GlusterFS 6.9, issue tested with Distributed volume and Replicated volume - same effect.
docker command to run service:
docker service create --replicas 1 --network masext --with-registry-auth \ --name owncloud \ --publish 8080:8080 \ --env OWNCLOUD_DB_TYPE=mysql \ --env OWNCLOUD_DB_NAME=my_database_name \ --env OWNCLOUD_DB_USERNAME=my_user \ --env OWNCLOUD_DB_PASSWORD=my_password \ --env OWNCLOUD_DB_HOST=my_databse_host \ --env OWNCLOUD_ADMIN_USERNAME=admin \ --env OWNCLOUD_ADMIN_PASSWORD=admin_pass \ --env OWNCLOUD_MYSQL_UTF8MB4=true \ --env OWNCLOUD_LOG_LEVEL=0 \ --mount type=bind,source=/mnt/volumes/owncloud,destination=/mnt/data \ owncloud/server:10.5.0
Any help would be appreciated.
