Owncloud Encryption
  1. Install Older version of Owncloud
  2. Turn on Encryption
  3. Turn off Encryption at some point
  4. Reload system completely
    5 Try to download old files
Old encryted files won’t display or download
Web server: Apache
Database: MySql
Integrity status for oC9+
paste the results here.
So here’s the story. Back with Owncloud 7 I turend on encryption. I added files and assumed it was also encrypting the files already uploaded. Since then I’ve upgrade Owncloud and even have done fresh installs. The latest being 9.1. Along the way I did backup the data files and owncloud files.
My question is, I have older files that were encrypted in Owncloud 7ish and now I can’t open them. Is there a way to decrypt them so that I can access these files?
I have the following files still:
encryption_migration_backup/
files_encryption/
Both dated Nov 2015. Is there anything in those files that I can use to retreive the older files?
I no longer have encryption enabled.
Greg
Did you read the documentation? There was a particular mechanism to be used for upgrading encrypted systems from 7 to 8.
When did you turn off encryption? I also used encryption at some point and turned it off later (turn off was in OC 7). After that, for most files it was ok. However, some files remained encrypted and I do not know why. For most of these files, the users still had an unencryption version synced, so we backed up this file from his client, then we cleaned out the old encrypted file.
Because the encryption scheme has changed since OC 7 and if you can’t recover the file from the client, I would perhaps try to setup an OC 7 session, create the users with the right passwords, then replace the keys with those of the old session. Then you can perhaps read them.
I will try that, Maybe recreating would be the way to go
Greg
