- open the owncloud.cfg file
- insert Flag promptDeleteAllFiles=false
- when trying to delete all files in ownCloud and then clicking merge changes it crashes.
ownCloud should delete all files without the warning message of “Remove All Files”? with the choices of Remove all files or to keep files when the files are deleted from the server, it used to work on v 2.6.x
but now it doesnt
now it just crashes with promptDeleteAllFiles=false
Ubuntu 16.04.7
Apache2
mysql
10.5
fresh
from the official website
