I’m a new user for ownCloud and I work on it in my graduation project…
I have a question about the file system type which ownCloud used. I installed ownCloud server on Ubuntu 14.04 which use ext4 as a file system. Does ownCloud use the same file system type of Ubuntu ? or it has a specific type?
Also, I have another question about the read-write file to memory functions . In which folder and files can I find their code?
Well i have to intervent on this point because of a really bad experience happened to me a few months ago.
From my POV i highly recommend to use Ubuntu 16.x + php7 and a filesystem with either EXT4(journalling, small block sizes) or BTRFS.
Why BTRFS? → it doesnt have the problems like EXT3/4 with missing INODES when people put shitloads of small files upon your system and its way easier to increment its partition- and systemsize (LVM).
Why am I saying this? Well, it happened way to often to me that customers/friends/clients have the synchronization for hidden-files and/or all-file-types activated (*.ini, *.dat, *.cmd etc) which bloats the INODES-“library” to its limitations, and then the webserver or mysql wont even start anymore…
for short:
use Ubuntu 16.x
use PHP 7
use either EXT4 with smaller Blocks or BTRFS Fileystem
Trust me, it will save you so much time afterwards
Hope nobody disagrees, because it would make me a disgrace to my family
