I am new to installing oC and I have some questions that I can’t resolve after searching the forums/docs:
Do I need to run an LDAP server on a separate machine? Can I run it on the same machine or somehow provide the same functionality/authentication services on the same machine the Ubuntu server and oC are running? (yea, I know this is not the best for security but would suffice for a small test bed.)
Is installing and running LAMP under Ubuntu acceptable? does it provide all the services that oC would require? OR stated another way, after doing a base install of Ubuntu server, what other services are required to install to support oC?
Are they any Apache (out of the box) config setting that need to be changed to support oC?
J
