As I am new to OwnCloud, I am facing some issues with it. I am building an API which gives me the details of the Directory and all the other important details to it. The API which I am using to fetch the details is…
With this I am able to get the details of the directories and files. But what if I have to get the details of the sub directory or Child Directory ??
For Example: IF I have Folders like ABC, DEF and file like abc.jpg than I am able to get all the details regarding this. But what if I want to get the details for the inner content of the ABC Folder.
And one more question: is there any way to get the file size without downloading it and without using webdav? Will I be able to get the file size from any other way?
Any help is greatly appreciated. ![]()
Thanks in Advance.
