- Adding files with server transfer, not with the web interface
- Manually scanning with occ files:scan
- Opening the folder in the web interface
Folder opened up as it should
I cant open the folder as it is always on loading spinner
**Operating systemCentos&:
**Web server:Apache
**Database:MariaDB
**PHP version:7.2
**ownCloud version:10.6 (see ownCloud admin page)
**Where did you install ownCloud from:Owncloud Download page
"datadirectory": "\/var\/www\/html\/owncloud\/data",
"overwrite.cli.url": "",
"dbtype": "mysql",
"version": "10.6.0.5",
"dbname": "****",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"filelocking.enabled": false,
"logtimezone": "UTC",
"apps_paths": [
"path": "\/var\/www\/html\/owncloud\/apps",
"url": "\/apps",
"writable": false
"path": "\/var\/www\/html\/owncloud\/apps-external",
"url": "\/apps-external",
"writable": true
"installed": true
