Apologies all if this is not correctly categorized…, or if there’s another way of letting OC about site issues, at this point in time I’m hoping this post will get to the correct team:
https://owncloud.org/features/ [See how to get started]
Redirects to “404. Oops! You’re lost. The page you’re looking for was not found**.”
Embedded url is:
[ https://doc.owncloud.org/server/latest/developer_manual/app/ ]
Tested on various browsers, same result. Perhaps the OC Web Development could have a look please?
Thanks!
this is a great catch. It seems the documentation was reworked not so long ago and various links are not updated yet.
If it doesn’t get noticed by the responsible people it seems there is a second possibility to report issues on the owncloud.org page here:
Hey Tom,
Thanks!! & thanks for the guidance, I’ve added (the post) to https://owncloud.org/news/owncloud-documentation-contribute/.
I’m sure it’ll get sorted.
Cheers!
Mig.
i’m not sure if the comments of a blogpost are the best place for this
Have you considered to try the github repository mentioned above?
Sorry that this took a while. Thanks for the notice. I fixed this just now.
