Hi everyone, I was running my own owncloud stack on a Hetzner mounted volume and everything was going well. I recently had to switch to a new Hetzner network drive that I mounted by following the instructions over on the docs. After running the mount.cifs
command and following the steps, I used the mv
command in order to transfer my whole owncloud stack to the new drive called sbox1
. Now after changing the respective mount points in the docker-compose.yml file via Portainer (went from /mnt/volume-nbg1
to /mnt/sbox1
) I started getting the following error which leads to MariaDB failing and restarting: portainer logs.
After searching around a bit, it seems like something got messed up with the permissions that the owncloud_mariadb container has, am I right on that? What do I need to change in order to get it its access back? I also imagine that there must be some database related files that need to be updated after such a major move. I saw this guide but I’m not using apache or have any database tools installed.
Here’s my docker-compose.yml file from the portainer editor:
version: "3"
services:
owncloud:
image: owncloud/server:latest
container_name: owncloud_server
restart: always
ports:
- [REDACTED]:8080
depends_on:
- mariadb
- redis
environment:
- PUID=0
- PGID=0
- OWNCLOUD_FOLDER=/mnt/sbox1/owncloud/data
- OWNCLOUD_DOMAIN=[REDACTED]
- OWNCLOUD_DB_TYPE=mysql
- OWNCLOUD_DB_NAME=owncloud
- OWNCLOUD_DB_USERNAME=owncloud
- OWNCLOUD_DB_PASSWORD=[REDACTED]
- OWNCLOUD_DB_HOST=mariadb
- OWNCLOUD_ADMIN_USERNAME=[REDACTED]
- OWNCLOUD_ADMIN_PASSWORD=[REDACTED]
- OWNCLOUD_MYSQL_UTF8MB4=true
- OWNCLOUD_REDIS_ENABLED=true
- OWNCLOUD_REDIS_HOST=redis
volumes:
- /mnt/sbox1/owncloud/data:/mnt/data
mariadb:
image: mariadb:10.5
container_name: owncloud_mariadb
restart: always
environment:
- MYSQL_ROOT_PASSWORD=[REDACTED]
- MYSQL_USER=owncloud
- MYSQL_PASSWORD=[REDACTED]
- MYSQL_DATABASE=owncloud
- PUID=0
- PGID=0
volumes:
- /mnt/sbox1/owncloud/mariadb:/var/lib/mysql
redis:
image: redis:6
container_name: owncloud_redis
restart: always
volumes:
- /mnt/sbox1/owncloud/redis:/data
The only thing that was changed after the drive switch was the volume mapping, like I mentioned above.
