I am wanting to set up my “own cloud” so I can store files that will be synched between several computers on different networks. I saw a post on the Resilio Sync blog dated 3-15-18 (https://www.resilio.com/blog/how-i-created-my-own-personal-cloud-using-bittorrent-sync-owncloud-and-raspberry-pi) and thought that would be the answer. The instructions were based on Raspbian “jessie”, and the commands installed versions of Apache2, PHP, SQlite and OwnCloud.
However…my Pi 3 Model B is running Debian 10.7 Buster, and when I log into the Pi (192.xxx.xxx.xx/owncloud), I get the following screen:
<?php /** * @author Jörn Friedrich Dreyer * @author Lukas Reschke * @author Morris Jobke * @author Philipp Schaffrath * @author RealRancor * @author Robin Appelman * @author Sergio BertolÃn * @author Thomas Müller * @author Vincent Petry * * @copyright Copyright (c) 2018, ownCloud GmbH * @license AGPL-3.0 * * This code is free software: you can redistribute it and/or modify * it under the terms of the GNU Affero General Public License, version 3, * as published by the Free Software Foundation. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU Affero General Public License for more details. * * You should have received a copy of the GNU Affero General Public License, version 3, * along with this program. If not, see * */ // Show warning if a PHP version below 7.2.0 is used, this has to happen here // because base.php will already use 7.2 syntax. if (\version_compare(PHP_VERSION, '7.2.0') === -1) { echo 'This version of ownCloud requires at least PHP 7.2.0'; echo 'You are currently running PHP ' . PHP_VERSION . '. Please update your PHP version.'; return; } // Show warning if PHP 7.5 or later is used as ownCloud is not compatible with PHP 7.5 if (\version_compare(PHP_VERSION, '7.5.0alpha1') !== -1) { echo 'This version of ownCloud is not compatible with PHP 7.5
'; echo 'You are currently running PHP ' . PHP_VERSION . '.'; return; } // running oC on Windows is unsupported since 8.1, this has to happen here because // is seems that the autoloader on Windows fails later and just throws an exception. if (\stripos(PHP_OS, 'WIN') === 0) { echo 'ownCloud Server does not support Microsoft Windows.'; return; } try { require_once __DIR__ . '/lib/base.php'; OC::handleRequest(); } catch (\OC\ServiceUnavailableException $ex) { \OC::$server->getLogger()->logException($ex, ['app' => 'index']); //show the user a detailed error page OC_Response::setStatus(OC_Response::STATUS_SERVICE_UNAVAILABLE); OC_Template::printExceptionErrorPage($ex); } catch (\OC\HintException $ex) { OC_Response::setStatus(OC_Response::STATUS_SERVICE_UNAVAILABLE); OC_Template::printErrorPage($ex->getMessage(), $ex->getHint()); } catch (\OC\User\LoginException $ex) { OC_Response::setStatus(OC_Response::STATUS_FORBIDDEN); OC_Template::printErrorPage($ex->getMessage()); } catch (\OCP\Files\ForbiddenException $ex) { OC_Response::setStatus(OC_Response::STATUS_FORBIDDEN); OC_Template::printErrorPage($ex->getMessage()); } catch (\Throwable $ex) { try { \OC::$server->getLogger()->logException($ex, ['app' => 'index']); //show the user a detailed error page OC_Response::setStatus(OC_Response::STATUS_INTERNAL_SERVER_ERROR); OC_Template::printExceptionErrorPage($ex); } catch (\Throwable $ex2) { // with some env issues, it can happen that the logger couldn't log properly, // so print out the exception directly // NOTE: If we've reached this point, something has gone really wrong because // we couldn't even get the logger, so don't rely on ownCloud here. \header("{$_SERVER['SERVER_PROTOCOL']} 599 Broken"); \OC::crashLog($ex); \OC::crashLog($ex2); } } The version of owncloud that was downloaded was owncloud-complete-20201216.tar.bz2, and the PHP is version 7.2 I am so new to all of this that I don't know where to go next. The installation instructions from the blog I referenced and other posts say that when I enter my local address/owncloud, I should be taken to the OwnCloud admin login page, but instead the page above shows up. I'd appreciate any help...do I need to uninstall (commands, if possible) packages, install new ones (which versions to be all compatible with each other?) and how do I make them all work with each other? Thanks very much
