I have Web server apache2 running with ssl
my root directory : / home/user1/www
I checked my Web server and Databse work well by the progrm dbmyadmin.
I unziped owncloud zip file in /home/user1/www
I connected https:://{mydomain}/owncloud.
It looked like working well but ‘Can’t create or write into the data directory’ message was returned.
I searched about that and I excuted the command line
sudo chown -R www-data:www-data /home/user1/www/owncloud
I connected https:://{mydomain}/owncloud. However, my Web server is returing ‘HTTP ERROR 500’
owncloud config file and log file is empty, apache2 log is like bellow.
Owncloud Configuration page
Error page HTTP ERROR 500
Operating system: Ubuntu 16.04.5
Web server: apache 2.4.18
Database: mysql 15.1
PHP version: 7.0.30
ownCloud version: 10.0.9
The content of config/config.php: config.php is empty
[Mon Aug 06 15:09:16.725410 2018] [:error] [pid 15393] [client 111.111.111.111:11111] PHP Warning: fopen(/home/user1/www/owncloud/config/config.php): failed to open stream: Permission denied in /home/user1/www/owncloud/lib/private/Config.php on line 252
[Mon Aug 06 15:09:16.725452 2018] [:error] [pid 15393] [client 111.111.111.111:11111] PHP Warning: flock() expects parameter 1 to be resource, boolean given in /home/user1/www/owncloud/lib/private/Config.php on line 262
[Mon Aug 06 15:09:16.725492 2018] [:error] [pid 15393] [client 111.111.111.111:11111] PHP Fatal error: Uncaught Error: Call to a member function getLogger() on null in /home/user1/www/owncloud/index.php:74\nStack trace:\n#0 {main}\n thrown in /home/user1/www/owncloud/index.php on line 74
ownCloud log is empty
How can I slove this problem?
Doens’t the ‘www-data’ work with ssl?
Please help my problem and sorry for my poor English.
Even it said ‘The loopback address, 127.0.0.1, is automatically whitelisted’, the config.php was empty in my case. However web server returns same reult after I added the trusted domains.
Before this step server returns Can’t create or write into the data directory message.
I understand this.
But after this run-the-installation-wizard step, server returns HTTP ERROR 500.
And apache2 error log is same as I asked. I can’t understand this situation.
I already got a ssl certification for my server, I don’t know how to connect with normal http. sorry…
Understanding is not enough! You have to adjust ownership and access rights of everything below the owncloud directory.
Your HTTP user must own the config/, data/, apps/ respectively the apps-external/ directories so that you can configure ownCloud, create, modify and delete your data files, and install apps via the ownCloud Web interface.
I also think that there is a permission issue if the logs in the initial post are still showing up. They are exactly pointing an “Permission denied” out.
Before the command 'chown -R www-data:www-data /home/user1/www/owncloud’
It shows configuration page but after that command it returns HTTP ERROR 500.
And apache error logs are same.
