1.Using a fresh and an up-to-date version of Raspberry OS 11 (bullseye), it is not possible to install owncloud via apt. apt-cache search owncloud results in the following output:
pi@rpi32:~ $ apt-cache search owncloud | fgrep owncloud
owncloud-antivirus - antivirus for ownCloud based on ClamAV - ownCloud application
owncloud-apps - third party applications for ownCloud
owncloud-music - music player and server - ownCloud application
owncloud-tasks - task management with CalDAV support - ownCloud application
Like in Raspberry OS 10 (buster), I expected a package named ‘owncloud’ to be available.
Package ‘ownlcoud’ is not there (yet?). Will it become available?
Raspberry OS 11 (bullseye), 32-bit
nginx version: nginx/1.18.0
Not applicable
PHP 8.0.1, php8.0-fpm
None
