Thanks for reporting issues back to ownCloud! This is the issue tracker of ownCloud, if you have any support question please check out ownCloud support and maintenance information for customers
This is the bug tracker for the Server component. Find other components at core/.github/CONTRIBUTING.md at master · owncloud/core · GitHub
For reporting potential security issues please see ownCloud security policies and information
To make it possible for us to help you please fill out below information carefully.
Before reporting any issues please make sure that you’re using the latest available version for your major branch (e.g. 9.0.x), see Changelog - ownCloud
### Steps to reproduce
1.
2.
3.
### Expected behaviour
Normal CPU usage
### Actual behaviour
High (100%) CPU usage
### Server configuration
Freenas
ownCloud 9.1.2 (stable)
fresh install
Freenas GUI Plugin page.
I can sign in with no problem.
** **Login as admin user into your ownCloud and access ** **http://example.com/index.php/settings/integrity/failed ** **paste the results into https://gist.github.com/ and puth the link here.** 'No errors have been found.' **
Can’t find this in OwnCloud Web GUI accesed through Freenas.
**or **
Command not recognized in OwnCloud FreeNas Jail.
Crashplan
Plex
** **If you have access to your command line run e.g.:** **sudo -u www-data php occ app:list** **from within your ownCloud installation folder.** **
Yes -
/Mnt/Archiefoud
/Mnt/Archiefnieuw
Are you using encryption: no
no
### Client configuration
Chrome
Freenas
### Logs
#### Web server error log
** **Insert your ownCloud log here** https://www.dropbox.com/s/426orw8o7rh8lx9/owncloud.log?dl=0 **
#### Browser log
** **Insert your browser log here, this could for example include:** I do not understand. **a) The javascript console log** **b) The network log ** **c) ...** **
Owncloud runs at 100% in Freenas. Uses high CPU, even when not used. Can’t figure out why.
see - Dropbox
Thanks,
Dion
