OwnCloud running on QNAP Platform
I was successfully running OwnCloud 10.0.0.1 on my QNAP Platform running Firmware QTS 5.1.8.2823. Since the latest upgrade to QTS 5.2.0.2860 it no longer works.
Can anybody help please?
i think if an QNAP app stopped to work then i think it is required that the QNAP app author is contacted for getting support for it. Maybe QNAP itself also offers support for your problem?
Thanks for your advice. QNAP assume no responsibility as OwnCloud is a third-party app. I find this frustrating as OwnCloud is still available from the QNAP App Site.
Kind regards
last year i have asked Get outdated ownCloud version removed from QNAP App Store? but how i understand this the people have no possibility to remove such outdated apps from the app store because they seems to be not the ones providing it :slightly_frowning_face:
But maybe you as a QNAP customer has the possibility to ask QNAP for a removal because i think 10.0.0.1 is heavily outdated, has been released on 2017-04-26 and i think should never be provided / offered for download in the QNAP app store anymore.
