Owncloud seems to ignore dbtype in config.php (using docker)
I’m an Owncloud newbie and would like to deploy a containerized version of Owncloud on my NAS (QNAP) as a private alternative to Dropbox.
I can run a docker container of Owncloud without any problem using the default sqlite database: I access the GUI, create the admin user, browse the file structure, etc.
But I’d like to switch to Mysql and I was so far unable to do as Owncloud “seems” to ignore the settings in config.php.
I created a MySQL instance (MariaDB) in a separate container and added an empty owncloud-reserved database to it: I checked that from the Owncloud container I can successfully login into the MySQL’s via the command line, so the database is reachable.
Following some instructions I found online I edited file config.php and changed field “installed” in variable $CONFIG from “true” to “false”: this triggers the db configuration wizard upon login.
In the wizard I select “MySQL” and await the completion of the setup procedure.
When it’s done I checked that:
  1. Owncloud tables have been created in the MariaDB database (the db was empty before runnig the wizard)
  2. The config.php file has been modified and now I see all mysql db settings, particulary:
    'dbtype' => 'mysql', (the file showed before the sqlite settings)
Despite the above, if I go to the Settings page of my admin user, under General I still see the red warning: “SQLite is used as database..etc”.
For testing, I added a new user and indeed the data are still stored in the sqlite file rather than MySQL
So my conclusion is that Owncloud is ignoring config.php in my setup.
Things I tried to no avail:
  1. Recreating the Owncloud container multiple times
  2. Restart the container after the database change
What am I missing?
Thanks in advance
Regards
  1. Trigger the database setup wizard by changing “installed” from “true” to “false” in config.php
  2. Run the db setup wizard
  3. Check that OC tables have been created in the new MYSQL database
  4. Go into Settings/General as Admin user
  5. The “SQLite is used as database” message is still displayed
Owncloud should use the new MySQL database and not display the warning message
Owncloud is still using the default sqlite database, apparently ignoring config.php
Linux
apache
MySQL (MariaDB)
10.6.0 (owncloud/server image on Docker Hub)
Fresh install
Docker Hub
(sensitive information has been redacted)
$CONFIG = array (
‘apps_paths’ =>
array (
0 =>
array (
‘path’ => ‘/var/www/owncloud/apps’,
‘url’ => ‘/apps’,
‘writable’ => false,
1 =>
array (
‘path’ => ‘/var/www/owncloud/custom’,
‘url’ => ‘/custom’,
‘writable’ => true,
‘trusted_domains’ =>
array (
0 => ‘192...:',
‘datadirectory’ => ‘/mnt/data/files’,
‘dbtype’ => ‘mysql’,
‘dbhost’ => '
‘dbname’ => ‘REDACTED’,
‘dbuser’ => ‘REDACTED’
‘dbpassword’ => ‘REDACTED’
‘dbtableprefix’ => ‘oc_’,
‘log_type’ => ‘owncloud’,
‘supportedDatabases’ =>
array (
0 => ‘sqlite’,
1 => ‘mysql’,
2 => ‘pgsql’,
‘upgrade.disable-web’ => true,
‘default_language’ => ‘en’,
‘overwrite.cli.url’ => ‘REDACTED’,
‘htaccess.RewriteBase’ => ‘/’,
‘logfile’ => ‘/mnt/data/files/owncloud.log’,
‘loglevel’ => 2,
‘filesystem_cache_readonly’ => false,
‘filelocking.enabled’ => true,
‘passwordsalt’ => ‘REDACTED’,
‘secret’ => ‘REDACTED’,
‘version’ => ‘10.6.0.5’,
‘logtimezone’ => ‘UTC’,
‘installed’ => true,
‘instanceid’ => ‘REDACTED’,
‘mysql.utf8mb4’ => true,
I get an error message;
    OC\DatabaseException: Invalid database type in /var/www/owncloud/lib/private/Server.php:533
No
SELECT * FROM oc_appconfig WHERE appid = ‘user_ldap’;
### Client configuration
**Browser:**
Firefox 84
**Operating system:**
Linux
I would try to make sqlite unavailable before installing, and/or remove any existing sqlite-db files.
Hi Alfred,
I did not remove any sqlite-db files (as far as I am aware) and what do you mean exactly by “making sqlite unavailable”?
Regards
S.
I just generated the Config Report and in the database section I still see:
    "dbtype": "sqlite",
    "dbhost": "",
    "dbname": "owncloud",
    "dbtableprefix": "oc_",
    "log_type": "owncloud",
    "supportedDatabases": [
        "sqlite",
        "mysql",
        "pgsql"
So evidently ownCloud is ignoring the config.php file.
The plot thickens…
I fixed it.
I just had to add a few more environmental variables with the appropriate values to the container, namely:
OWNCLOUD_DB_TYPE
OWNCLOUD_DB_HOST
OWNCLOUD_DB_NAME
OWNCLOUD_DB_USERNAME
OWNCLOUD_DB_PASSWORD
Hope this helps someone else.
S.
Where did you add those values?
