ownCloud Server maintenance releases: 9.1.4 RC2, 9.0.8 RC2, 8.2.10 RC2, 8.1.12 RC2
Here are the archives for the release candidates of ownCloud
Server:
You can download the tarballs at the following links:
You can find the changelog below.
The branches stable9.1, stable9, stable8.2 and stable8.1 are now frozen, which means that only fixes for showstopper issues will be merged. Others will be moved to the next point milestone.
Please give these versions a good test and report any issues in
GitHub - owncloud/core: ☁ ownCloud web server core (Files, DAV, etc.) or the bug trackers of the related
apps.
In case you are wondering why there was no RC1, it’s because we discovered some issues during early testing of the tarballs, so a RC2 was built with the fix.
Thanks to everyone who has contributed !
Changelog:
9.1.4 RC2
  • [major] Make error message for password reset form more generic - core/#27011
  • [major] When sharing autocomplete is disabled, also disable for the email field - core/#26504
  • [major] Add command to clean up invalid/expired remote storages - core/#26379
  • [major] Fix encryption key storage when using LDAP home folder rules - core/#26820
  • [major] Properly react on memcache errors - core/#25692
  • [major] Fix random normalizedPathCache log messages / garbage collection issues from PHP 7 - core/#22370
  • [major] Properly deal with inconsistent LDAP/memcache or user/group manager responses - core/#26871
  • [major] Added configreport app which will help with better bug reports - configreport/#6
  • [minor] Fix syncing of file names with colon followed by a number - core/#25479
  • [minor] Prevent empty user uid from LDAP - user_ldap/#6
  • [minor] Prevent repeated log messages when dealing with broken picture files - core/#26758
  • [minor] Fix group-enable option in apps page when memcache is enabled - core/#26638
  • [minor] Add AVMaxFileSize config option - files_antivirus/#133
  • [minor] Reduce number of federated share requests when dealing with non-existing entries - core/#26324
  • [minor] Remove obsolete legacy storage repair routine - core/#26774
  • [minor] Fix broken remote avatar image in activities tab - activity/#529
  • [minor] When grouping duplicate shares, sort by stime then id - core/#25830
  • [minor] Make file upload post hooks consistent between chunking and non-chunking mode - core/#26387
  • [minor] Fix wrong German translation in upload progress bar by using momentjs library - core/#26804
  • [minor] Skip unavailable storages in background file scan instead of failing - core/#26055
  • [minor] Update PHP 7.1 incompatibility warning - core/#26982
  • [minor] Warning notification when uploading 4+ GB file in IE11 - core/#27004
9.0.8 RC2
  • [major] Fix performance regression with many received shares - core/#26912
  • [major] Prevent LDAP avatar to be duplicated repeatedly in vCard - core/#26242
8.2.10 RC2
  • [major] Fix LDAP “undefined OfflineUser::composeAndStoreDisplayName()” - core/#25588
8.1.12 RC2
Final versions were released: ownCloud Server maintenance releases 9.1.4, 9.0.8, 8.2.10, 8.1.12
