Owncloud SMTP error
Hei,
after owncloud upgrade 9.1.2 to 9.1.4 not working SMTP
I give this error:
A problem occurred while sending the email. Please revise your settings. (Error: Failed to authenticate on SMTP server with username “cuser@email.com” using 0 possible authenticators)
Any solution ?
I use:
Ubuntu server 16.04.2
PHP version 7.1.2
Apache 2.4.25
If something like this is happening after an update (like from 9.1.2 to 9.1.4) without any changes to the main infrastructure / setup then please always report it directly to the developers at the bugtracker → GitHub · Where software is built
Hei,
okey…many thanks.
Oh, sorry. I’ve just noticed:
ownCloud 9.1.x is not compatible with PHP 7.1. How did you managed to get this running? Only ownCloud 10 coming in a few weeks will be compatible with PHP 7.1
Sorry, i use PHP 5
Nextcloud using PHP 7.1.2 :slight_smile:
ref: Owncloud 9.1.4 SMTP error · Issue #27325 · owncloud/core · GitHub
