Good morning everyone,
when on the browser I type the IP address / owncloud I get this error:
“Safari cannot open the page: https: // IP / owncloud. Error:” load cannot follow more than 20 redirections ".
Hello Nemo,
You need to get a real DNS
I had the same error when I tried free DNS.
This is but merely a stab in the dark, for real help please fill out the template or provide more info about your setup / issue.
Best Regards
Dmitry
Currently I have not set up any free DNS … I only installed openssl …
I will try to reinstall openssl by activating a free DNS first …
If you tell me what I could post to help you the most
Can you post the documentation you used to set up your ownCloud? The error message can indicate a redirection loop as well, so your Apache vHost configuration might help as well.
for apache and the database i used these commands:
sudo apt install apache2 apache2-utils
sudo systemctl start apache2
sudo systemctl enable apache2
sudo apt install mariadb-server mariadb-client
sudo apt install mysql-server mysql-client
sudo systemctl start mariadb
sudo systemctl enable mariadb
sudo mysql_secure_installation
Blockquote
For sslcertificate:
sudo openssl genrsa -out server.key 4096
sudo openssl req -new -key server.key -out server.csr
there will be some entries to fill in, but the most important one is COMMON NAME, which I have pointed to my DynDNS hostname for remote access:
sudo openssl x509 -req -days 1825 -in server.csr -signkey server.key -out server.crt -sha256
sudo chmod 400 server.key
sudo mv server.key /root/server.key
sudo mv server.crt /root/server.crt
sudo cp /etc/apache2/sites-available/000-default.conf /etc/apache2/sites-available/000-default.conf_bak
sudo nano /etc/apache2/sites-available/000-default.conf
Below the DocumentRoot line we write:
Permanent redirect / https: // myIP /
Then again:
sudo nano /etc/apache2/sites-available/default-ssl.conf
and edit the entries, SSLCertificateFile, SSLCertificateKeyFile, as below:
SSLCertificateFile /root/server.crt
SSLCertificateKeyFile /root/server.key
At the end of this file we add:
Header always set Strict-Transport-Security "max-age = 15552000; includeSubDoma $
enable encryption:
sudo a2ensite default-ssl.conf
sudo service apache2 reload
sudo a2enmod ssl
sudo service apache2 restart
Blockquote
