- Enable Crontab as desrcibed in documentation
- Install mcrypt for crontab to work
- try to reach Owncloud (either client or web)
Owncloud works
Error Message:
Exception occurred while logging exception: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] Connection refused
#0 /var/www/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /var/www/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /var/www/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /var/www/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /var/www/cloud/lib/private/DB/Connection.php(147): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /var/www/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#6 /var/www/cloud/lib/private/DB/ConnectionFactory.php(145): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#7 /var/www/cloud/lib/private/Server.php(487): OC\DB\ConnectionFactory->getConnection(‘mysql’, Array)
#8 /var/www/cloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#9 /var/www/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘DatabaseConnect…’)
#10 /var/www/cloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘DatabaseConnect…’)
#11 /var/www/cloud/lib/private/Server.php(1147): OC\ServerContainer->query(‘DatabaseConnect…’)
#12 /var/www/cloud/lib/private/Server.php(239): OC\Server->getDatabaseConnection()
#13 /var/www/cloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#14 /var/www/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘AccountMapper’)
#15 /var/www/cloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘AccountMapper’)
#16 /var/www/cloud/lib/private/Server.php(999): OC\ServerContainer->query(‘AccountMapper’)
#17 /var/www/cloud/lib/private/Server.php(244): OC\Server->getAccountMapper()
#18 /var/www/cloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#19 /var/www/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘UserManager’)
#20 /var/www/cloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘UserManager’)
#21 /var/www/cloud/lib/private/Server.php(992): OC\ServerContainer->query(‘UserManager’)
#22 /var/www/cloud/lib/private/Server.php(288): OC\Server->getUserManager()
#23 /var/www/cloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#24 /var/www/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘UserSession’)
#25 /var/www/cloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘UserSession’)
#26 /var/www/cloud/lib/private/Server.php(1016): OC\ServerContainer->query(‘UserSession’)
#27 /var/www/cloud/lib/private/Server.php(541): OC\Server->getUserSession()
#28 /var/www/cloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
#29 /var/www/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘AppManager’)
#30 /var/www/cloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘AppManager’)
#31 /var/www/cloud/lib/private/Server.php(1346): OC\ServerContainer->query(‘AppManager’)
#32 /var/www/cloud/lib/private/legacy/app.php(343): OC\Server->getAppManager()
#33 /var/www/cloud/lib/private/legacy/app.php(111): OC_App::getEnabledApps()
#34 /var/www/cloud/lib/base.php(579): OC_App::loadApps(Array)
#35 /var/www/cloud/lib/base.php(1014): OC::init()
#36 /var/www/cloud/index.php(54): require_once(’/var/www/cloud/…’)
#37 {main}
Operating system: ubuntu16.04.1
Web server: apache2
Database: Mysql
PHP version: 7.1
ownCloud version: 10.0.4.4
'datadirectory' => '/var/www/cloud/data',
'overwrite.cli.url' => '/',
Are you using encryption: no
