I install apache2 and mysql and phpmyadmin set by set. I was able to access them after install. Once I installed owncloud I can not access them anymore. All I get is the background for owncloud welcome screen and
File not found
The specified document has not been found on the server.
Owncloud:9.1.4
Ubuntu 16.04 Lts
I installed using terminal. I thought I did everything right.
When I go to http://localhost it goes to owncloud. But I can’t get to http://localhost/phpmyadmin it goes to an owncloud background and gives me a message and a link to go back to the main login page to owncloud. I actually came across anything problem now too. With trying to setup ask now everything is broken. Http://localhost says unable to connect.
I did as the instructions said on owncloud but does seem to work.
The ones on owncloud’s website. I was trying to set up https. This happen before that. Not on my computer next time I am, I will send the config file and the apache files.
