I attempted to run the updater from the web UI. Unfortunately I did not have zip/unzip installed on Ubuntu, which crashed the updater. From here on the web interface is broken, prompting me to run occ upgrade, but occ upgrade fails with the following message:
Exception: Environment not properly prepared. in /var/www/html/lib/private/Console/Application.php:135
Stack trace:
#0 /var/www/html/console.php(105): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#1 /var/www/html/occ(11): require_once('/var/www/html/c...')
How can I roll back to the checkpoint the updater created?
- run updater from web UI
- ensure zip/unzip is not installed on the server
complete update without error
see error above
Operating system: Ubuntu 18.04
Web server: Apache2
Database: Mysql 5.7
PHP version: 7.2
ownCloud version: 10.0.0.4 to 10.1.0
Updated from an older ownCloud or fresh install: updating from old
Where did you install ownCloud from: owncloud.org
cannot run occ config:list system, same error as above
