Owncloud updater zip error
I want to upgrade with updater, but i get following error:
  1. Initializing
    Current version is 10.0.9.5
    Online version is 10.0.10 [production]
    Start
    Checking system
    Creating a checkpoint
    Downloading
    Updating core
    Extracting source into /var/www/vhosts/_________/ownclouddata/updater-data/_oc_upgrade/10.0.10
    Extraction has been failed
    e[RuntimeException] e
    eThere was an error extracting the ZIP file. Corrupt file? e
eupgrade:executeCoreUpgradeScriptse
I want to upgrade 10.0.9.5 to 10.0.10 with updater
I get this error: There was an error extracting the ZIP file. Corrupt file? e
NAME=“CentOS Linux”
VERSION=“7 (Core)”
ID=“centos”
ID_LIKE=“rhel fedora”
PHP version: PHP Version 7.0.32
ownCloud version: 10.0.9.5
Updated from an older ownCloud or fresh install: Updated manually from 10.0.9
```No errors have been found.
‘admin’ -> ‘Generate Config Report’ -> ‘Download ownCloud config report’
“zip”: {
“Zip”: “enabled”,
“Zip version”: “1.13.5”,
“Libzip version”: “1.1.2”
**Are you using encryption:** no
Unzip from terminal: unzip 10.0.10.zip -d ../_oc_upgrade/10.0.10/ works fine
If you can extract it on the command line, but not in the web, you might have a problem with the php zip package:
sudo apt-get install -y php7.2-zip
https://doc.owncloud.com/server/10.0/admin_manual/installation/source_installation.html#install-the-required-packages
I would also check the permissions on your ownCloud directory, make sure the web server user has access.
Could you also check if you have enough free space available?
