After performing an update of owncloud-files (that went smoothly btw) I was prompted to run "php occ upgrade".
I did, following appeared:
www-data@oc:~/owncloud$ php occ upgrade
Exception: DateTimeZone::__construct(): Unknown or bad timezone (UTC+1) in /var/www/owncloud/lib/private/Console/TimestampFormatter.php:100
Stack trace:
#0 /var/www/owncloud/lib/private/Console/TimestampFormatter.php(100): DateTimeZone->__construct('UTC+1')
#1 /var/www/owncloud/lib/composer/symfony/console/Output/Output.php(157): OC\Console\TimestampFormatter->format('')
#2 /var/www/owncloud/lib/composer/symfony/console/Output/Output.php(134): Symfony\Component\Console\Output\Output->write(Array, true, 16)
#3 /var/www/owncloud/lib/composer/symfony/console/Application.php(621): Symfony\Component\Console\Output\Output->writeln('', 16)
#4 /var/www/owncloud/lib/composer/symfony/console/Application.php(127): Symfony\Component\Console\Application->renderException(Object(Exception), Object(Symfony\Component\Console\Output\StreamOutput))
#5 /var/www/owncloud/lib/private/Console/Application.php(160): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#6 /var/www/owncloud/console.php(106): OC\Console\Application->run()
#7 /var/www/owncloud/occ(11): require_once('/var/www/ownclo...')
How should I proceed after this?
Loaded apps:
Enabled:
- announcementcenter: 1.2.0
- comments: 0.3.0
- configreport: 0.1.1
- customgroups: 0.3.1
- dav: 0.2.9
- external: 1.2
- federatedfilesharing: 0.3.0
- federation: 0.1.0
- files: 1.5.1
- files_antivirus: 0.10.0.0
- files_external: 0.7.0
- files_sharing: 0.10.0
- files_trashbin: 0.9.0
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.2.1
- notifications: 0.3.0
- provisioning_api: 0.5.0
- richdocuments: 1.1.23
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
- user_external: 0.4
- user_ldap: 0.9.1
Disabled:
- encryption
- theme-example
